WIN7, CUDA8 - Driver Version 376.51 , VS2012
// Prepare to run
m_context->validate();
double start, end_compile, end_AS_build;
sutilCurrentTime(&start);
m_context->compile();
sutilCurrentTime(&end_compile);
std::cerr << "Time to compile kernel: "<<end_compile-start<<" s.\n";
m_context->launch(0,0); # <-- failure
sutilCurrentTime(&end_AS_build);
std::cerr << "Time to build AS : "<<end_AS_build-end_compile<<" s.\n";
FATAL: appname.exe: Signal 11 was received.
f:\dd\vctools\crt_bld\self_64_amd64\crt\src\thr\mutex.c(38): mutex destroyed while busy
Caught exception during startup: Unknown error (Details: Function "_rtContextLaunch1D" caught C++ standard exception: device or resource busy)
Any idea what might cause this sort of error after changing OptiX versions to 4.1.0?
