This error popped up:
packages/sensors/V4L2Camera.cpp@149: [V4L2Camera] Error: driver has changed pixel format to: 540422490
Again pls give us full context?
What’s your set up?
Workstation HW/SW Configuration? GPU? GPU Driver? Jetson? etc.
Any updates on this issue? I am facing the same problem. I am running the program on workstation. I can run the ‘realsense-viewer’ program provided by Intel without problems.
Info:
Error code:
PANIC packages/sensors/V4L2Camera.cpp@149: [V4L2Camera] Error: driver has changed pixel format to: 540422490
OS: Ubuntu 18.04
Realsense Firmware: v5.10.03 (I also tried to upgrade to the latest version, but still the same error)
USB: USB3.2 port
Thank you,
The problem is resolved by downgrading linux kernel to 4.x.
I tried running samples
<isaac_sdk_home>/apps/samples/april_tag and
<isaac_sdk_home>/apps/samples/v4l2_camera
with Logitech HD Pro Webcam C920 and both the samples work without downgrading the linux kernel to 4.x.
In order to solve the problem for Realsense D435(without downgrading the linux kernel to 4.x), try to do the following
Your app.json file sould look something like
"name": "april_tags",
"modules": [
"//packages/perception:april_tags",
"viewers",
"realsense"
"graph": {
"nodes": [
"name": "input_images",
"components": [
"name": "isaac.alice.MessageLedger",
"type": "isaac::alice::MessageLedger"
"name": "isaac.Realsense",
"type": "isaac::RealsenseCamera"
"name": "april_tags_detection",
"components": [
"name": "isaac.perception.AprilTagsDetection",
"type": "isaac::perception::AprilTagsDetection"
"name": "isaac.viewers.FiducialsViewer",
"type": "isaac::viewers::FiducialsViewer"
"name": "image_viewers",
"components": [
"name": "isaac.viewers.ColorCameraViewer",
"type": "isaac::viewers::ColorCameraViewer"
"edges": [
"source": "input_images/isaac.Realsense/color",
"target": "april_tags_detection/isaac.perception.AprilTagsDetection/image"
"source": "april_tags_detection/isaac.perception.AprilTagsDetection/april_tags",
"target": "april_tags_detection/isaac.viewers.FiducialsViewer/fiducials"
"target": "image_viewers/isaac.viewers.ColorCameraViewer/color_listener"
"config": {
"april_tags_detection": {
"isaac.perception.AprilTagsDetection": {
"max_tags": 50
"input_images": {
"isaac.V4L2Camera": {
"device_id": 0,
"rows": 448,
"cols": 800,
"rate_hz": 30
"websight": {
"WebsightServer": {
"port": 3000,
"ui_config": {
"windows": {
"Tags": {
"renderer": "2d",
"channels": [
{ "name": "april_tags/image_viewers/isaac.viewers.ColorCameraViewer/Color" },
{ "name": "april_tags/april_tags_detection/isaac.viewers.FiducialsViewer/fiducials" }
Thank you Swapnesh, your solution is perfect!
