Failure of Generate API key for Docker Installation
Software Version
[✔] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[✔] Linux
QNX
other
Hardware Platform
[✔] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.3.10904
[✔] other
Host Machine Version
[✔] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I’m trying to install docker image, but I’m not getting “Generate API key” option. I am attaching a snippet of the same.
Hi @avani.babithanair ,
Thanks for bringing this to our attention. I am checking on this and update you.
Dear @avani.babithanair,
Have you selected driveos/driveos-sdk? If so, please confirm if you see Generate API key option under driveos/No team
Dear @SivaRamaKrishnaNV ,
Thank you for your response.
I have checked with this, I can’t able to find Generate API key option under driveos/driveos-sdk. But I can able to find it under ‘No team’
Currently, please use Generate API key option under “No Team”. Let us know if you see any issues.
I acknowledge that we are able to generate an API key under the option ‘No Team’. Following that, we log in to the NGC registry using the API key, as shown in the attached screenshot.
Before proceeding to flash the Docker image, we want to confirm if the previous steps were done right. Once we’re sure about that, we can move on to flashing.
I see you are able to login nvcr.io. Please file a new topic if you face any issue with pulling the docker image.
We can generate an API key and successfully flash the Docker image onto the device. You may now close the thread. Thank you again.
