Failure rate of Jetson Orin NX 16GB
Please let me know the FIT (Failure In Time) rate for the Jetson Orin NX 16GB, if available.
We are uncertain what FIT is. Please share more information about it.
The estimated failure rate is a measure used to predict the frequency at which a system or component is expected to fail over a specified period of time. It is often expressed in terms of failures per unit of time, such as failures per hour or failures per year. This metric is crucial in reliability engineering and helps in planning maintenance schedules, improving system designs, and ensuring safety and efficiency.
FIT = (Total number of failures) / ((Total number of tests × Time) × Temperature acceleration factor)
This is a value commonly used in many semiconductors.
You can get the MTBF value in Orin NX datasheet in DLC and calculate FIT by 1/MTBF/10^(-9).
