Hi!
In installed pgi 8.0 successfully last year but need to change the hostname recently to allow the proper creation of mpd rings (for mpich2). I have gone into the license.dat file and changed the name from localhost.localdomain to airpolicy1 (as specified in my /etc/hosts file) and followed the instructions for restarting the license manager. However I am getting the following (usual) error:
12:31:10 (lmgrd) -----------------------------------------------
12:31:10 (lmgrd) Please Note:
12:31:10 (lmgrd)
12:31:10 (lmgrd) This log is intended for debug purposes only.
12:31:10 (lmgrd) In order to capture accurate license
12:31:10 (lmgrd) usage data into an organized repository,
12:31:10 (lmgrd) please enable report logging. Use Macrovision’s
12:31:10 (lmgrd) software license administration solution,
12:31:10 (lmgrd) FLEXnet Manager, to readily gain visibility
12:31:10 (lmgrd) into license usage data and to create
12:31:10 (lmgrd) insightful reports on critical information like
12:31:10 (lmgrd) license availability and usage. FLEXnet Manager
12:31:10 (lmgrd) can be fully automated to run these reports on
12:31:10 (lmgrd) schedule and can be used to track license
12:31:10 (lmgrd) servers and usage across a heterogeneous
12:31:10 (lmgrd) network of servers including Windows NT, Linux
12:31:10 (lmgrd) and UNIX. Contact Macrovision at
12:31:10 (lmgrd) www.macrovision.com for more details on how to
12:31:10 (lmgrd) obtain an evaluation copy of FLEXnet Manager
12:31:10 (lmgrd) for your enterprise.
12:31:10 (lmgrd)
12:31:10 (lmgrd)
12:31:10 (lmgrd)
12:31:10 (lmgrd) The license server manager (lmgrd) running as root:
12:31:10 (lmgrd) This is a potential security problem
12:31:10 (lmgrd) and is not recommended.
12:31:10 (lmgrd) Failed to open the TCP port number in the license.
When I try and pgf77 -V x.f I get (not suprisingly) a series of failure to checkout error messages and a cannot connect to server error. Finally, I get a FLEXnet licensing error -15,570 System Error: 101 “Network is unreachable”
I know in one of the other posts with a similar problem there was some question regarding resetting the firewall and the port settings but I have tried this with no effect.
I’m sure this is very simple but I am out of ideas.
Any and all suggestions are greatly appreciated.
Thanks,
David
