I am new to Cardhu dev kit and I have been scratching my head on flashing the JB image. I tried flashing on 32-bit Ubuntu first and failed. Then I found the guide document and followed exactly the description on Windows. I’ve been able to install the recovery driver and place the kit in forced recovery mode. I received the identical error message on Linux when I ran flashos.bat file.
Here is the command window output:
C:\NVPACK\Android_OS_Images\Cardhu\ics-rel-15-2012-10-19-18-18-12-13166542-cardh
u>flashos.bat
u>nvflash.exe --bct flash.bct --setbct --odmdata 0x40080000 --configfile flash.c
fg --create --bl bootloader.bin --go
Nvflash started
rcm version 0X30001
System Information:
chip name: unknown
chip id: 0x30 major: 1 minor: 3
chip sku: 0x81
chip uid: 0x015c7b47ea2bf208
macrovision: disabled
hdcp: enabled
sbk burned: false
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 1
sending file: flash.bct
- 6128/6128 bytes sent
flash.bct sent successfully
odm data: 0x40080000
downloading bootloader – load address: 0x80108000 entry point: 0x80108000
sending file: bootloader.bin
data send failed NvError 0x120002
command failure: bootloader download failed (bad data)
u>
