Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I’m getting an error when trying to flash Xavier board with version 5.2.0. I retried a few times, but error keeps happening. At the moment, it seems both Tegra A and B are not booting into linux.
11:57:49 INFO: Flash Xavier A+B in parallel - flash: Pre flash script found! Calling scripts/linux_pre_flash.sh
11:57:56 INFO: Flash Xavier A+B in parallel - flash:
11:57:56 INFO: Flash Xavier A+B in parallel - flash: Running flash command: sudo -E /home/gordon/storage/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh -b e3550b03-t194 -B qspi -x /dev/ttyUSB3
12:03:07 INFO: Flash Xavier A+B in parallel - flash: [bootburnTegra-B]: [DisplayHostInfoAndPaths(306)] : Host release 5.4.0-81-generic
12:03:07 INFO: Flash Xavier A+B in parallel - flash: [bootburn]: [startADBServer(134)] : Starting ADB server
12:03:07 INFO: Flash Xavier A+B in parallel - flash: Exception caught in bootburn
12:03:08 INFO: Flash Xavier A+B in parallel - flash: Flashing process exited with error 17
12:03:08 INFO: Flash Xavier A+B in parallel - flash: pdkinstaller cannot continue! Check the log file for details: /home/gordon/storage/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/pdkinstaller/pdkinstaller.log
12:03:08 ERROR: Flash Xavier A+B in parallel - flash: command terminated with error
**12:03:08 SUMMARY: Flash Xavier A+B in parallel - flash: First Error: Installation failed.**
Please share the complete logs (compress ~/.nvsdk and upload it).
On the same host system, have you successfully flashed 5.2.0 onto another platform?
Could you try with the latest SDK Manager (1.6.1)?
Yes, I’ve used same host PC to flash another xavier to 5.2.0 before. I also updated to latest SDK manager after I got a failure to flash, but it didn’t help.
I can’t find ~/.nvsdk directory on my PC, there is however a .nvsdkm directory. nvsdkm.tar.xz (1.8 MB)
