I decided to re-do all the process…
I think the official guide should mention the .run trick to not install the shadow driver.
Here are the steps to install the cuda toolkit on a fresh WSL Ubuntu 18.04 install:
$ sudo apt update
$ sudo apt install build-essentials
$ sudo sh cuda_11.0.1_450.36.06_linux.run
Uncheck the nvidia driver:
Ignore the warning:
WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least .00 is required for CUDA 11.0 functionality to work.
To install the driver using this installer, run the following command, replacing with the name of this run file:
sudo .run --silent --driver
Logfile is /var/log/cuda-installer.log
$ cd /usr/local/cuda-11.0/samples/1_Utilities/deviceQuery
$ make
$ ./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: “TITAN RTX”
CUDA Driver Version / Runtime Version 11.1 / 11.0
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 24576 MBytes (25769803776 bytes)
(72) Multiprocessors, ( 64) CUDA Cores/MP: 4608 CUDA Cores
GPU Max Clock rate: 1770 MHz (1.77 GHz)
Memory Clock rate: 7001 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 6291456 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 6 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 101 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >Device 1: “GeForce GTX 1080 Ti”
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 11264 MBytes (11811160064 bytes)
(28) Multiprocessors, (128) CUDA Cores/MP: 3584 CUDA Cores
GPU Max Clock rate: 1582 MHz (1.58 GHz)
Memory Clock rate: 5505 Mhz
Memory Bus Width: 352-bit
L2 Cache Size: 2883584 bytes
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Concurrent copy and kernel execution: Yes with 5 copy engine(s)
Device PCI Domain ID / Bus ID / location ID: 0 / 23 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >Peer access from TITAN RTX (GPU0) → GeForce GTX 1080 Ti (GPU1) : No
Peer access from GeForce GTX 1080 Ti (GPU1) → TITAN RTX (GPU0) : NodeviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.1, CUDA Runtime Version = 11.0, NumDevs = 2
Result = PASS
Thank you! I would never guessed that the .run is different than the .deb cuda toolkit.
