Hi, I’m trying to do realtime detection using YOLOv3 but I keep getting error. Anyone can assist me in solving this problem?
When I run ls -l /dev/video0
, it give a feedback.
When I run simple_camera.py from GitHub - JetsonHacksNano/CSI-Camera: Simple example of using a CSI-Camera (like the Raspberry Pi Version 2 camera) with the NVIDIA Jetson Developer Kit, it working too
When I run python3 darknet_video.py, it failure
Error:
My darknet_videp.py code:
from ctypes import *
import random
import os
import cv2
import time
import darknet
import argparse
from threading import Thread, enumerate
from queue import Queue
def parser():
parser = argparse.ArgumentParser(description=“YOLO Object Detection”)
parser.add_argument(“–input”, type=str, default=0,
help=“video source. If empty, uses webcam 0 stream”)
parser.add_argument(“–out_filename”, type=str, default=“”,
help=“inference video name. Not saved if empty”)
parser.add_argument(“–weights”, default=“yolov4.weights”,
help=“yolo weights path”)
parser.add_argument(“–dont_show”, action=‘store_true’,
help=“windown inference display. For headless systems”)
parser.add_argument(“–ext_output”, action=‘store_true’,
help=“display bbox coordinates of detected objects”)
parser.add_argument(“–config_file”, default=“./cfg/yolov4.cfg”,
help=“path to config file”)
parser.add_argument(“–data_file”, default=“./cfg/coco.data”,
help=“path to data file”)
parser.add_argument(“–thresh”, type=float, default=.25,
help=“remove detections with confidence below this value”)
return parser.parse_args()
def str2int(video_path):
argparse returns and string althout webcam uses int (0, 1 …)
Cast to int if needed
try:
return int(video_path)
except ValueError:
return video_path
def check_arguments_errors(args):
assert 0 < args.thresh < 1, “Threshold should be a float between zero and one (non-inclusive)”
if not os.path.exists(args.config_file):
raise(ValueError(“Invalid config path {}”.format(os.path.abspath(args.config_file))))
if not os.path.exists(args.weights):
raise(ValueError(“Invalid weight path {}”.format(os.path.abspath(args.weights))))
if not os.path.exists(args.data_file):
raise(ValueError(“Invalid data file path {}”.format(os.path.abspath(args.data_file))))
if str2int(args.input) == str and not os.path.exists(args.input):
raise(ValueError(“Invalid video path {}”.format(os.path.abspath(args.input))))
def set_saved_video(input_video, output_video, size):
fourcc = cv2.VideoWriter_fourcc(*“MJPG”)
fps = int(input_video.get(cv2.CAP_PROP_FPS))
video = cv2.VideoWriter(output_video, fourcc, fps, size)
return video
def video_capture(frame_queue, darknet_image_queue):
while cap.isOpened():
ret, frame = cap.read()
if not ret:
break
frame_rgb = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
frame_resized = cv2.resize(frame_rgb, (width, height),
interpolation=cv2.INTER_LINEAR)
frame_queue.put(frame_resized)
darknet.copy_image_from_bytes(darknet_image, frame_resized.tobytes())
darknet_image_queue.put(darknet_image)
cap.release()
def inference(darknet_image_queue, detections_queue, fps_queue):
darknet_image = darknet_image_queue.get()
prev_time = time.time()
detections = darknet.detect_image(network, class_names, darknet_image, thresh=args.thresh)
detections_queue.put(detections)
fps = int(1/(time.time() - prev_time))
fps_queue.put(fps)
print(“FPS: {}”.format(fps))
darknet.print_detections(detections, args.ext_output)
darknet.free_image(darknet_image)
cap.release()
def drawing(frame_queue, detections_queue, fps_queue):
random.seed(3) # deterministic bbox colors
video = set_saved_video(cap, args.out_filename, (width, height))
frame_resized = frame_queue.get()
detections = detections_queue.get()
fps = fps_queue.get()
if frame_resized is not None:
image = darknet.draw_boxes(detections, frame_resized, class_colors)
image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
if args.out_filename is not None:
video.write(image)
if not args.dont_show:
cv2.imshow(‘Inference’, image)
keyCode = cv2.waitKey(30) & 0xFF
if keyCode == 27:
break
cap.release()
video.release()
cv2.destroyAllWindows()
def gstreamer_pipeline(
capture_width=3280,
capture_height=2464,
display_width=820,
display_height=616,
framerate=21,
flip_method=0,
return (
"nvarguscamerasrc ! "
"video/x-raw(memory:NVMM), "
"width=(int)%d, height=(int)%d, "
"format=(string)NV12, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
“video/x-raw, format=(string)BGR ! appsink”
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
if name == ‘main’:
frame_queue = Queue()
darknet_image_queue = Queue(maxsize=1)
detections_queue = Queue(maxsize=1)
fps_queue = Queue(maxsize=1)
args = parser()
network, class_names, class_colors = darknet.load_network(
args.config_file,
args.data_file,
args.weights,
batch_size=1
# Darknet doesn't accept numpy images.
# Create one with image we reuse for each detect
width = darknet.network_width(network)
height = darknet.network_height(network)
darknet_image = darknet.make_image(width, height, 3)
input_path = str2int(args.input)
#cap = cv2.VideoCapture(input_path)
cap = cv2.VideoCapture(gstreamer_pipeline(), cv2.CAP_GSTREAMER)
Thread(target=video_capture, args=(frame_queue, darknet_image_queue)).start()
Thread(target=inference, args=(darknet_image_queue, detections_queue, fps_queue)).start()
Thread(target=drawing, args=(frame_queue, detections_queue, fps_queue)).start()
Anyone have facing similar problem?
