Failure to start first time after reboot after OTA or after flash
Jetson AGX Xavier Devkit
L4T32.7.1
It can be avoided by turning the power back on.
But it is not a fundamental solution, so please push for a solution!
L4T32.7.1
I don’t think this issue would be reproduced with pure flash.
Are you flashing to emmc or nvme? Have you tried to clean up your BSP and let sdkamanger download it again and flash?
hello WayneWWW,
Flush to emmc.
The same phenomenon occurs when I create the environment again with sdkmanager.
After you use /dev/ttyACM0 interface to create user account, will you see the GUI coming out?
Also, could you share the full log from uart when this error happened?
Paste the boot log.
Situation
When L4T32.6.1 was written by SDK Manager, the boot failed.
[1529.064] I> Writing mts-mce partition.
[1529.108] I> Writing mts-mce_b partition.
[1529.131] I> Writing mts-proper partition.
[1529.350] I> Writing mts-proper_b partition.
[1529.505] I> Writing cpu-bootloader partition.
[1529.578] I> Writing cpu-bootloader_b partition.
[1529.613] I> Writing bootloader-dtb partition.
[1529.691] I> Writing bootloader-dtb_b partition.
[1529.720] I> Writing secure-os partition.
[1529.794] I> Writing secure-os_b partition.
[1529.827] I> Writing eks partition.
[1529.856] I> Writing eks_b partition.
[1529.877] I> Writing bpmp-fw partition.
[1529.949] I> Writing bpmp-fw_b partition.
[1529.996] I> Writing bpmp-fw-dtb partition.
[1530.071] I> Writing bpmp-fw-dtb_b partition.
[1530.125] I> Writing xusb-fw partition.
[1530.278] I> Writing xusb-fw_b partition.
[1530.290] I> Writing rce-fw partition.
[1530.457] I> Writing rce-fw_b partition.
[1530.484] I> Writing adsp-fw partition.
[1530.588] I> Writing adsp-fw_b partition.
[1530.611] I> Writing sc7 partition.
[1530.700] I> Writing sc7_b partition.
[1530.739] I> Writing BMP partition.
[1530.776] I> Writing BMP_b partition.
[1530.800] I> Writing recovery partition.
[1533.628] I> Writing recovery-dtb partition.
[1533.706] I> Writing kernel-bootctrl partition.
[1533.731] I> Writing kernel-bootctrl_b partition.
[1533.747] I> Writing kernel partition.
[1537.444] I> Writing kernel_b partition.
[1539.140] I> Writing kernel-dtb partition.
[1539.230] I> Writing kernel-dtb_b partition.
[1539.300] I> Writing BCT partition.
[1539.451] I> Writing MB1_BCT partition.
[1539.482] I> Writing MB1_BCT_b partition.
[1539.509] I> Writing MEM_BCT partition.
[1539.561] I> Writing MEM_BCT_b partition.
[1539.767] I> Rebooting : reset-coldboot
����Shutdown state requested 1
Rebooting system ...
[0000.053] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet lev.
[0000.062] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.067] I> Boot-mode: Coldboot
[0000.070] I> Chip revision : A02
[0000.073] I> Bootrom patch version : 15 (correctly patched)
[0000.078] I> ATE fuse revision : 0x200
[0000.082] I> Ram repair fuse : 0x0
[0000.085] I> Ram Code : 0x2
[0000.088] I> rst_source : 0xb
[0000.090] I> rst_level : 0x1
[0000.094] I> Boot-device: eMMC
[0000.109] I> sdmmc DDR50 mode
[0000.113] W> No valid slot number is found in scratch register
[0000.118] W> Return default slot: _a
[0000.122] I> Active Boot chain : 0
[0000.125] I> Boot-device: eMMC
[0000.128] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.135] I> Temperature = 45500
[0000.138] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.142] W> Skipping boost for clk: BPMP_APB
[0000.146] W> Skipping boost for clk: AXI_CBB
[0000.150] W> Skipping boost for clk: AON_CPU_NIC
[0000.154] W> Skipping boost for clk: CAN1
[0000.158] W> Skipping boost for clk: CAN2
[0000.162] I> Boot-device: eMMC
[0000.165] I> Boot-device: eMMC
[0000.175] I> Sdmmc: HS400 mode enabled
[0000.179] I> ECC region[0]: Start:0x0, End:0x0
[0000.183] I> ECC region[1]: Start:0x0, End:0x0
[0000.187] I> ECC region[2]: Start:0x0, End:0x0
[0000.191] I> ECC region[3]: Start:0x0, End:0x0
[0000.196] I> ECC region[4]: Start:0x0, End:0x0
[0000.200] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.205] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.210] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.214] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.219] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.224] E> FAILED: Thermal config
[0000.232] E> FAILED: MEMIO rail config
[0000.250] I> Boot-device: eMMC
[0000.259] I> sdmmc bdev is already initialized
[0000.332] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.340] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8)
[0000.341] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.341] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.342] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.348] W> device prod register failed
[0000.352] I> Boot-device: eMMC
[0000.354] I> Boot_device: SDMMC_BOOT instance: 3
[0000.360] I> sdmmc-3 params source = boot args
[0000.363] I> sdmmc bdev is already initialized
[0000.367] I> sdmmc-3 params source = boot args
[0000.376] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.382] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.383] W> No valid slot number is found in scratch register
[0000.388] W> Return default slot: _a
[0000.392] I> Active Boot chain : 0
[0000.395] I> parsing oem signed section of bpmp-fw header done
[0000.401] I> bpmp-fw binary init read from storage
[0000.406] I> oem authentication of bpmp-fw header done
[0000.412] I> bpmp-fw binary done read from storage
[0000.415] I> bpmp-fw: Authentication init Done
[0000.420] I> parsing oem signed section of cpubl header done
[0000.425] I> cpubl binary init read from storage
[0000.429] I> bpmp-fw: Authentication Finalize Done
[0000.434] I> oem authentication of cpubl header done
[0000.439] I> cpubl binary done read from storage
[0000.443] I> cpubl: Authentication init Done
[0000.448] I> parsing oem signed section of rce header done
[0000.453] I> rce binary init read from storage
[0000.457] I> Relocating BR-BCT
[0000.460] I> cpubl: Authentication Finalize Done
[0000.465] I> oem authentication of rce header done
[0000.469] I> rce binary done read from storage
[0000.473] I> rce: Authentication init Done
[0000.478] I> parsing oem signed section of ape header done
[0000.482] I> ape binary init read from storage
[0000.487] I> rce: Authentication Finalize Done
[0000.491] I> oem authentication of ape header done
[0000.496] I> ape binary done read from storage
[0000.500] I> ape: Authentication init Done
[0000.505] I> parsing oem signed section of tos header done
[0000.509] I> tos binary init read from storage
[0000.514] I> ape: Authentication Finalize Done
[0000.518] I> oem authentication of tos header done
[0000.522] I> tos binary done read from storage
[0000.527] I> tos: Authentication init Done
[0000.531] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.537] I> bpmp-fw-dtb binary init read from storage
[0000.542] I> tos: Authentication Finalize Done
[0000.548] I> oem authentication of bpmp-fw-dtb header done
[0000.554] I> bpmp-fw-dtb binary done read from storage
[0000.556] I> bpmp-fw-dtb: Authentication init Done
[0000.561] I> parsing oem signed section of cpubl-dtb header done
[0000.567] I> cpubl-dtb binary init read from storage
[0000.572] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.610] I> oem authentication of cpubl-dtb header done
[0000.610] I> cpubl-dtb binary done read from storage
[0000.611] I> cpubl-dtb: Authentication init Done
[0000.613] I> parsing oem signed section of eks header done
[0000.614] I> eks binary init read from storage
[0000.614] I> cpubl-dtb: Authentication Finalize Done
[0000.615] I> oem authentication of eks header done
[0000.618] I> eks binary done read from storage
[0000.623] I> eks: Authentication init Done
[0000.627] I> eks: Authentication Finalize Done
[0000.631] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.134] I> Welcome to Cboot
��fmon_post initialized
��[0001.135] I> Cboot Version: t194-cfa2bc91
[0001.135] I> CPU-BL Params @ 0xf2820000
[0001.136] I> 0) Base:0x00000000 Size:0x00000000
[0001.139] I> 1) Base:0xf1100000 Size:0x00100000
[0001.144] I> 2) Base:0xf2000000 Size:0x00200000
[0001.148] I> 3) Base:0xf1200000 Size:0x00200000
[0001.153] I> 4) Base:0xf1000000 Size:0x00100000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.157] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.237] I> 6) Base:0xf3800000 Size:0x00400000
[0001.241] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.246] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.250] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.254] I> 10) Base:0xf3000000 Size:0x00800000
[0001.259] I> 11) Base:0x40000000 Size:0x00040000
[0001.263] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.268] I> 13) Base:0x40046000 Size:0x00002000
[0001.272] I> 14) Base:0x40048000 Size:0x00002000��emc_debugfs initialized
dvs_debugfs initialized
[0001.282] I> 15) Base:0xac000000 Size:0x00004000��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.332] I> 16) Base:0x4004a000 Size:0x00002000
[0001.336] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.341] I> 18) Base:0x4004c000 Size:0x00002000
[0001.345] I> 19) Base:0xf2200000 Size:0x00600000
[0001.350] I> 20) Base:0x4004e000 Size:0x00002000
[0001.354] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.359] I> 22) Base:0x00000000 Size:0x00000000
[0001.363] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.368] I> 24) Base:0xf6000000 Size:0x02000000
[0001.372] I> 25) Base:0x40050000 Size:0x00002000
[0001.377] I> 26) Base:0x40040000 Size:0x00006000
[0001.381] I> 27) Base:0xf1800000 Size:0x00400000
[0001.386] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.390] I> 29) Base:0xf1400000 Size:0x00400000
[0001.394] I> 30) Base:0x00000000 Size:0x00000000
[0001.399] I> 31) Base:0x00000000 Size:0x00000000
[0001.403] I> 32) Base:0xf8000000 Size:0x08000000
[0001.408] I> 33) Base:0x00000000 Size:0x00000000
[0001.412] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.417] I> 35) Base:0xab000000 Size:0x01000000
[0001.421] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.426] I> 37) Base:0xf2800000 Size:0x00800000
[0001.430] I> 38) Base:0x80000000 Size:0x20000000
[0001.435] I> 39) Base:0xb0000000 Size:0x08000000
[0001.439] I> 40) Base:0x00000000 Size:0x00000000
[0001.444] I> 41) Base:0x00000000 Size:0x00000000
[0001.448] I> 42) Base:0x00000000 Size:0x00000000
[0001.453] I> 43) Base:0x00000000 Size:0x00000000
[0001.457] I> 44) Base:0x00000000 Size:0x00000000
[0001.461] I> 45) Base:0x00000000 Size:0x00000000
[0001.466] GIC-SPI Target CPU: 0
[0001.469] Interrupts Init done
[0001.472] calling constructors
[0001.475] initializing heap
[0001.477] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.482] initializing threads
[0001.484] initializing timers
[0001.487] creating bootstrap completion thread
[0001.492] top of bootstrap2()
[0001.494] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.499] initializing platform
[0001.502] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.507] W> device prod register failed
[0001.511] I> Bl_dtb @0xaaf00000
[0001.517] W> "plugin-manager" doesn't exist, creating
[0001.519] W> "ids" doesn't exist, creating
[0001.523] W> "connection" doesn't exist, creating
[0001.528] W> "configs" doesn't exist, creating
[0001.542] E> failed to read label property for node 227172: 13
[0001.544] E> failed to read reg property for node 227260: 13
[0001.547] E> failed to read label property for node 227312: 13
[0001.550] E> failed to read label property for node 227380: 13
[0001.556] E> failed to read label property for node 227416: 13
[0001.561] E> failed to read label property for node 227452: 13
[0001.567] E> failed to read reg property for node 227520: 13
[0001.572] E> failed to read label property for node 227572: 13
[0001.579] I> Find /i2c@3160000's alias i2c0
[0001.581] I> Reading eeprom i2c=0 address=0x50
[0001.611] I> Device at /i2c@3160000:0x50
[0001.611] I> Reading eeprom i2c=0 address=0x56
[0001.635] I> Device at /i2c@3160000:0x56
[0001.636] I> Find /i2c@3180000's alias i2c2
[0001.637] I> Reading eeprom i2c=2 address=0x54
[0001.638] E> I2C: slave not found in slaves.
[0001.639] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start t.
[0001.640] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.640] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 a.
[0001.649] E> eeprom: Failed to read I2C slave device
[0001.654] I> Eeprom read failed 0x3526070d
[0001.658] I> Reading eeprom i2c=2 address=0x57
[0001.663] E> I2C: slave not found in slaves.
[0001.666] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.674] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.680] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.689] E> eeprom: Failed to read I2C slave device
[0001.694] I> Eeprom read failed 0x3526070d
[0001.698] I> Reading eeprom i2c=2 address=0x52
[0001.703] E> I2C: slave not found in slaves.
[0001.707] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.714] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.720] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.729] E> eeprom: Failed to read I2C slave device
[0001.734] I> Eeprom read failed 0x3526070d
[0001.739] I> Find /i2c@c240000's alias i2c1
[0001.742] I> Reading eeprom i2c=1 address=0x52
[0001.748] E> I2C: slave not found in slaves.
[0001.751] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.759] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.764] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.774] E> eeprom: Retry to read I2C slave device.
[0001.779] E> I2C: slave not found in slaves.
[0001.783] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start t.
[0001.790] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.796] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 a.
[0001.805] E> eeprom: Failed to read I2C slave device
[0001.810] I> Eeprom read failed 0x3526070d
[0001.814] I> Reading eeprom i2c=1 address=0x50
[0001.819] E> I2C: slave not found in slaves.
[0001.823] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.830] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.836] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.846] E> eeprom: Retry to read I2C slave device.
[0001.850] E> I2C: slave not found in slaves.
[0001.854] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.862] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.868] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.877] E> eeprom: Failed to read I2C slave device
[0001.882] I> Eeprom read failed 0x3526070d
[0001.886] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0001.891] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.902] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0001.907] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.918] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.927] W> "i2c@3160000" doesn't exist, creating
[0001.930] W> "module@0x50" doesn't exist, creating
[0001.935] I> Adding plugin-manager/ids/2822-0000-600=/i2c@3160000:module@0x56
[0001.942] W> "module@0x56" doesn't exist, creating
[0001.948] I> Adding plugin-manager/cvm
[0001.950] W> "chip-id" doesn't exist, creating
[0001.954] I> Adding plugin-manager/chip-id/A02
[0001.959] I> Plugin-manager override starting
[0001.964] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.972] I> node /plugin-manager/fragement-soft-wdt matches
[0001.979] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.983] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.997] I> Disable plugin-manager status in FDT
[0001.998] I> Plugin-manager override finished successfully
[0001.998] I> gpio framework initialized
[0002.001] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' drir
[0002.008] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon'r
[0002.014] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.022] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.030] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.036] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.042] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.050] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.058] W> fetch_driver_phandle_from_dt: failed to get node with compatible 9
[0002.064] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.072] I> fixed regulator driver initialized
[0002.083] I> register 'maxim' power off handle
[0002.084] I> virtual i2c enabled
[0002.084] I> registered 'maxim,max20024' pmic
[0002.086] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.093] I> Boot-device: eMMC
[0002.096] I> Boot_device: SDMMC_BOOT instance: 3
[0002.104] I> sdmmc-3 params source = boot args
[0002.105] I> create_pm_ids: id: 2888-0004-400-K, len: 15
[0002.110] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.121] I> create_pm_ids: id: 2822-0000-600-G, len: 15
[0002.126] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.137] I> sdmmc bdev is already initialized
[0002.141] I> sdmmc-3 params source = boot args
[0002.172] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.184] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.194] I> enabling 'vdd-hdmi-5v0' regulator
[0002.200] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.201] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.201] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.206] E> invalid display type
[0002.210] E> invalid display type
[0002.211] E> cannot find any other nvdisp nodes
[0002.211] E> no valid display unit config found in dtb
[0002.213] W> display init failed
[0002.213] I> Load in CBoot Boot Options partition and parse it
[0002.223] E> Error -9 when finding node with path /boot-configuration
[0002.224] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO fil.
[0002.231] I> Using default boot order
[0002.234] I> boot-dev-order :-
[0002.237] I> 1.sd
[0002.239] I> 2.usb
[0002.241] I> 3.nvme
[0002.243] I> 4.emmc
[0002.245] I> 5.net
[0002.247] I> Hit any key to stop autoboot: 4 3 2 1
[0004.254] initializing target
[0004.254] calling apps_init()
[0004.255] starting app kernel_boot_app
[0004.274] I> found decompressor handler: lz4-legacy
[0004.275] I> decompressing BMP blob ...
[0004.286] I> Kernel type = Normal
[0004.286] I> ########## SD (0) boot ##########
[0004.287] I> No sdcard
[0004.287] I> -0 params source =
[0004.287] E> Blockdev open: exit error
[0004.287] E> SD boot failed, err: 724238353
[0004.288] I> ########## USB (0) boot ##########
[0004.293] W> No valid slot number is found in scratch register
[0004.293] W> Return default slot: _a
[0004.301] I> Validate XUSB-FW ...
[0004.301] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.305] I> Encryption fuse is not ON
[0004.308] I> USB Firmware Version: 60.09 release
[0004.368] I> regulator of usb2-0 already enabled
[0004.375] I> regulator of usb2-1 already enabled
[0004.383] I> regulator of usb2-2 already enabled
[0004.393] I> enabling 'vdd-5v-sata' regulator
[0005.462] I> USB 2.0 port 4 new high-speed USB device detected
[0005.463] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42ce2000
[0005.564] I> Start to enumerate device
[0005.565] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42ce2000
[0005.570] I>
[0005.570] I> Enumerated USB Device 2109:2812
[0005.571] I>
[0005.572] I> Hub:
[0005.572] I> Downstream ports : 4
[0005.572] I> Power switching : Ganged
[0005.573] I> Compound device : No
[0005.573] I> Over-current protection : Global
[0005.577] I> Hub avg delay : 4 ns
[0005.581] I> Enable hub ports
[0005.604] I> Device detected on port 2
[0005.612] I> Device detected on port 4
[0006.017] I> Device detected on port 1
[0006.625] I> Reset port 1
[0006.646] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42ce2000
[0006.747] I> Start to enumerate device
[0006.748] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa42ce2000
[0006.752] I> This device is non-MSD, skip enumeration
[0006.756] I> Reset port 2
[0006.819] I> Port 2 device is low speed, skip enumeration
[0006.825] I> Reset port 4
[0006.886] I> Port 4 device is low speed, skip enumeration
[0006.886] E> Enumerated device doesn't belong to MSD class or protocol is not !
[0006.887] E> Class = 9, Protocol = 0
[0006.887] E> USBMSD: Failed to initialize Enumerated USB device either not an .
[0006.892] E> Error opening USBMSD driver 0, err: 7c7c0312
[0006.897] W> Failed to initialize device 5-0
[0006.901] E> USB boot failed, err: 2088502034
[0006.906] I> ########## NVME (0) boot ##########
[0006.910] I> Initializing nvme device instance 0
[0006.914] I> Initializing nvme controller
[0006.918] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.925] I> vpcie3v3-supply not found
[0006.928] I> vpcie12v-supply not found
[0006.932] W> Failed to get nvidia,plat-gpios
[0006.936] I> tegrabl_pcie_soc_preinit: (0):
[0006.940] I> Unpowergate
[0006.943] I> tegrabl_car_clk_disable(0) ...
[0006.946] I> tegrabl_car_rst_set(CORE, 0) ...
[0006.951] I> tegrabl_car_rst_set(APB, 0) ...
[0006.955] I> tegrabl_car_clk_enable(0) ...
[0006.959] I> tegrabl_car_rst_clear(APB, 0) ...
[0006.963] I> tegrabl_set_ctrl_state(0)
[0006.967] I> CLR PCIE_APB:6
[0006.969] I> tegrabl_pcie_soc_init: (0):
[0006.973] I> APPL initialization ...
[0006.976] I> poweron phys
[0006.979] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0006.985] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0006.991] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0006.996] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0007.001] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0008.107] C> Failed to link up controller-0
[0008.107] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0008.108] I> Failed to initialize SoC Host PCIe controller
[0008.108] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x12
[0008.109] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0008.109] W> Failed to open NVME-0, err = 80800612
[0008.114] W> Failed to initialize device 10-0
[0008.118] E> NVME (0) boot failed, err: 0x80800612
[0008.122] I> ########## NVME (1) boot ##########
[0008.127] I> Initializing nvme device instance 1
[0008.131] I> Initializing nvme controller
[0008.135] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0008.142] I> vpcie3v3-supply not found
[0008.145] I> vpcie12v-supply not found
[0008.149] W> Failed to get nvidia,plat-gpios
[0008.153] I> tegrabl_pcie_soc_preinit: (1):
[0008.157] I> Unpowergate
[0008.159] I> tegrabl_car_clk_disable(1) ...
[0008.163] I> tegrabl_car_rst_set(CORE, 1) ...
[0008.168] I> tegrabl_car_rst_set(APB, 1) ...
[0008.172] I> tegrabl_car_clk_enable(1) ...
[0008.176] I> tegrabl_car_rst_clear(APB, 1) ...
[0008.180] I> tegrabl_set_ctrl_state(1)
[0008.184] I> CLR PCIE_APB:6
[0008.186] I> tegrabl_pcie_soc_init: (1):
[0008.190] I> APPL initialization ...
[0008.193] I> poweron phys
[0008.196] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0008.202] I> tegrabl_power_on_phy: power on phy @0x3e10000
[0008.309] I> PCIe controller-1 link is up
[0008.309] I> tegra_pcie_info[1].cfg0_base = 0x30000000
[0008.310] I> tegra_pcie_info[1].cfg1_base = 0x30020000
[0008.310] I> tegra_pcie_info[1].atu_dma_base = 0x30040000
[0008.310] I> tegra_pcie_bus[1].mem = 0x30200000
[0008.311] I> Scanning busnr: 0 devfn: 0
[0008.311] I> PCIe IDs: 0x1ad210de
[0008.314] I> PCIe RID_CC: 0x60400a1
[0008.317] I> Scanning busnr: 1 devfn: 0
[0008.321] I> PCIe IDs: 0x91711b4b
[0008.324] I> PCIe RID_CC: 0x1060113
[0008.328] I> PCI Config: I/O=0x30100000, Memory=0x30200000
[0008.333] I> IO bar_num=0 bar=0x30100000
[0008.337] I> IO bar_num=1 bar=0x30100008
[0008.340] I> IO bar_num=2 bar=0x30100010
[0008.344] I> IO bar_num=3 bar=0x30100018
[0008.348] I> IO bar_num=4 bar=0x30100020
[0008.352] I> MEM bar_num=5 bar=0x30200000
[0008.356] I> Number of PCIe devices detected: 2
[0008.360] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(1); error=0x0
[0008.367] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0008.373] W> Failed to open NVME-1, err = 80800612
[0008.378] W> Failed to initialize device 10-1
[0008.382] E> NVME (1) boot failed, err: 0x80800612
[0008.387] I> ########## NVME (2) boot ##########
[0008.391] I> Initializing nvme device instance 2
[0008.395] I> Initializing nvme controller
[0008.400] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0008.406] I> vpcie3v3-supply not found
[0008.409] I> vpcie12v-supply not found
[0008.413] W> Failed to get nvidia,plat-gpios
[0008.417] I> tegrabl_pcie_soc_preinit: (2):
[0008.421] I> Unpowergate
[0008.424] I> tegrabl_car_clk_disable(2) ...
[0008.427] I> tegrabl_car_rst_set(CORE, 2) ...
[0008.432] I> tegrabl_car_rst_set(APB, 2) ...
[0008.436] I> tegrabl_car_clk_enable(2) ...
[0008.440] I> tegrabl_car_rst_clear(APB, 2) ...
[0008.444] I> tegrabl_set_ctrl_state(2)
[0008.448] I> CLR PCIE_APB:6
[0008.450] I> tegrabl_pcie_soc_init: (2):
[0008.454] I> APPL initialization ...
[0008.457] I> poweron phys
[0008.460] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0008.466] I> tegrabl_power_on_phy: controller 2 not available
[0008.472] E> Failed to power on phy on controller-2
[0008.477] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0008.481] I> Failed to initialize SoC Host PCIe controller
[0008.487] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0008.493] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0008.500] W> Failed to open NVME-2, err = 80800601
[0008.504] W> Failed to initialize device 10-2
[0008.509] E> NVME (2) boot failed, err: 0x80800601
[0008.513] I> ########## NVME (3) boot ##########
[0008.518] I> Initializing nvme device instance 3
[0008.522] I> Initializing nvme controller
[0008.526] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0008.532] I> vpcie3v3-supply not found
[0008.536] I> vpcie12v-supply not found
[0008.540] W> Failed to get nvidia,plat-gpios
[0008.544] I> tegrabl_pcie_soc_preinit: (3):
[0008.548] I> Unpowergate
[0008.550] I> tegrabl_car_clk_disable(3) ...
[0008.554] I> tegrabl_car_rst_set(CORE, 3) ...
[0008.558] I> tegrabl_car_rst_set(APB, 3) ...
[0008.562] I> tegrabl_car_clk_enable(3) ...
[0008.566] I> tegrabl_car_rst_clear(APB, 3) ...
[0008.571] I> tegrabl_set_ctrl_state(3)
[0008.574] I> CLR PCIE_APB:6
[0008.577] I> tegrabl_pcie_soc_init: (3):
[0008.581] I> APPL initialization ...
[0008.584] I> poweron phys
[0008.587] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0008.593] I> tegrabl_power_on_phy: power on phy @0x3e80000
[0009.698] C> Failed to link up controller-3
[0009.699] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0009.699] I> Failed to initialize SoC Host PCIe controller
[0009.700] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x12
[0009.700] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0009.701] W> Failed to open NVME-3, err = 80800612
[0009.705] W> Failed to initialize device 10-3
[0009.709] E> NVME (3) boot failed, err: 0x80800612
[0009.714] I> ########## NVME (4) boot ##########
[0009.719] I> Initializing nvme device instance 4
[0009.723] I> Initializing nvme controller
[0009.727] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0009.733] I> vpcie3v3-supply not found
[0009.737] I> vpcie12v-supply not found
[0009.740] W> Failed to get nvidia,plat-gpios
[0009.745] I> tegrabl_pcie_soc_preinit: (4):
[0009.749] I> Unpowergate
[0009.751] I> tegrabl_car_clk_disable(4) ...
[0009.755] I> tegrabl_car_rst_set(CORE, 4) ...
[0009.759] I> tegrabl_car_rst_set(APB, 4) ...
[0009.763] I> tegrabl_car_clk_enable(4) ...
[0009.767] I> tegrabl_car_rst_clear(APB, 4) ...
[0009.772] I> tegrabl_set_ctrl_state(4)
[0009.775] I> CLR PCIE_APB:6
[0009.778] I> tegrabl_pcie_soc_init: (4):
[0009.781] I> APPL initialization ...
[0009.785] I> poweron phys
[0009.788] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0009.794] I> tegrabl_power_on_phy: controller 4 not available
[0009.799] E> Failed to power on phy on controller-4
[0009.804] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0009.809] I> Failed to initialize SoC Host PCIe controller
[0009.814] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0009.821] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0009.827] W> Failed to open NVME-4, err = 80800601
[0009.832] W> Failed to initialize device 10-4
[0009.836] E> NVME (4) boot failed, err: 0x80800601
[0009.841] I> ########## NVME (5) boot ##########
[0009.845] I> Initializing nvme device instance 5
[0009.850] I> Initializing nvme controller
[0009.854] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0009.860] I> i=0, reg_phandle=0x1b
[0009.866] I> reg_voltage=3300000
[0009.866] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1b, 33000)
[0009.878] I> enabling 'vdd-3v3-pcie' regulator
[0009.879] I> i=1, reg_phandle=0x1c
[0009.883] I> reg_voltage=1200000
[0009.884] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1c, 12000)
[0009.896] I> enabling 'vdd-12v-pcie' regulator
[0009.897] I> tegrabl_pcie_soc_preinit: (5):
[0009.900] I> Unpowergate
[0009.902] I> tegrabl_car_clk_disable(5) ...
[0009.906] I> tegrabl_car_rst_set(CORE, 5) ...
[0009.910] I> tegrabl_car_rst_set(APB, 5) ...
[0009.915] I> tegrabl_car_clk_enable(5) ...
[0009.918] I> tegrabl_car_rst_clear(APB, 5) ...
[0009.923] I> tegrabl_set_ctrl_state(5)
[0009.926] I> CLR PCIE_APB:6
[0009.929] I> tegrabl_pcie_soc_init: (5):
[0009.933] I> APPL initialization ...
[0009.936] I> poweron phys
[0009.939] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0009.945] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0009.950] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0009.956] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0009.961] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0009.966] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0009.972] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0009.977] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0009.982] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0011.088] C> Failed to link up controller-5
[0011.088] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0011.089] I> Failed to initialize SoC Host PCIe controller
[0011.089] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0011.090] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0011.090] W> Failed to open NVME-5, err = 80800612
[0011.095] W> Failed to initialize device 10-5
[0011.099] E> NVME (5) boot failed, err: 0x80800612
[0011.104] I> ########## Fixed storage boot ##########
[0011.108] I> Loading kernel-bootctrl from partition
[0011.113] I> Loading partition kernel-bootctrl at 0xa4350000 from device(0x1)
[0011.126] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0011.127] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0011.140] I> Already published: 00010003
[0011.141] I> Look for boot partition
[0011.141] I> Fallback: assuming 0th partition is boot partition
[0011.147] I> Detect filesystem
[0011.174] I> Loading extlinux.conf ...
[0011.175] I> Loading extlinux.conf binary from rootfs ...
[0011.175] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0011.218] I> Loading extlinux.conf sig file from rootfs ...
[0011.218] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0011.243] I> Validate extlinux.conf ...
[0011.243] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0011.244] I> Encryption fuse is not ON
[0011.244] I> L4T boot options
[0011.244] I> [1]: "primary kernel"
[0011.244] I> Enter choice:
[0014.246] I> Continuing with default option: 1
[0014.246] I> Loading kernel ...
[0014.246] I> Loading kernel binary from rootfs ...
[0014.247] I> rootfs path: /sdmmc_user/boot/Image
[0014.465] I> Loading kernel sig file from rootfs ...
[0014.466] I> rootfs path: /sdmmc_user/boot/Image.sig
[0014.484] I> overload load_size to 34484232 (from 34484240)
[0014.485] I> Validate kernel ...
[0014.485] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0014.799] I> Encryption fuse is not ON
[0014.828] I> Loading kernel-dtb ...
[0014.828] I> No kernel-dtb binary path
[0014.828] I> Continue to load from partition ...
[0014.829] W> No valid slot number is found in scratch register
[0014.829] W> Return default slot: _a
[0014.829] I> A/B: bin_type (38) slot 0
[0014.830] I> Loading kernel-dtb from partition
[0014.831] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0014.846] I> Validate kernel-dtb ...
[0014.846] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0014.851] I> Encryption fuse is not ON
[0014.852] I> Loading ramdisk from rootfs ...
[0014.856] I> Loading ramdisk binary from rootfs ...
[0014.860] I> rootfs path: /sdmmc_user/boot/initrd
[0014.923] I> Loading ramdisk sig file from rootfs ...
[0014.923] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0014.942] I> overload load_size to 7238344 (from 7238352)
[0014.942] I> Validate ramdisk ...
[0014.942] I> T19x: Authenticate ramdisk (bin_type: 54), max size 0x4000000
[0015.009] I> Encryption fuse is not ON
[0015.022] I> Kernel hdr @0xa4350000
[0015.022] I> Kernel dtb @0x90000000
[0015.023] I> decompressor handler not found
[0015.023] I> Copying kernel image (34484232 bytes) from 0xa4350000 to 0x800800e
[0015.034] I> Updated bpmp info to DTB
[0015.035] I> Ramdisk: Base: 0x92000000; Size: 0x6e72c8
[0015.036] I> Updated initrd info to DTB
[0015.036] W> WARN: Fail to override "console=none" in commandline
[0015.037] I> Active rootfs suffix:
[0015.038] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0015.046] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0015.053] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0015.060] W> No valid slot number is found in scratch register
[0015.066] W> Return default slot: _a
[0015.069] I> Active slot suffix:
[0015.072] I> add_boot_slot_suffix: slot_suffix =
[0015.077] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb earlycon=tegr
[0015.101] I> Updated bootarg info to DTB
[0015.105] W> MAC addr invalid!
[0015.108] E> Failed to get WIFI MAC address
[0015.112] W> MAC addr invalid!
[0015.115] E> Failed to get Bluetooth MAC address
[0015.119] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:e5:8f:b1
[0015.126] W> "plugin-manager" doesn't exist, creating
[0015.131] I> Adding /chosen/plugin-manager/cvm
[0015.135] W> "chip-id" doesn't exist, creating
[0015.139] I> Adding /chosen/plugin-manager/chip-id
[0015.144] W> "configs" doesn't exist, creating
[0015.148] I> Adding /chosen/plugin-manager/configs
[0015.152] W> "ids" doesn't exist, creating
[0015.157] I> Adding /chosen/plugin-manager/ids
[0015.161] W> "odm-data" doesn't exist, creating
[0015.165] I> Adding /chosen/plugin-manager/odm-data
[0015.173] W> "memory" doesn't exist, creating
[0015.174] I> [0] START: 0x80000000, END: 0xac000000
[0015.179] I> [1] START: 0xac004000, END: 0xf0ad0000
[0015.183] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0015.188] I> dram_block larger than 80000000
[0015.192] I> [3] START: 0x100000000, END: 0x880000000
[0015.197] I> added [base:0x80000000, size:0x2c000000] to /memory
[0015.203] I> added [base:0xac200000, size:0x44800000] to /memory
[0015.209] I> added [base:0x100000000, size:0x780000000] to /memory
[0015.216] I> Updated memory info to DTB
[0015.219] E> add_disp_param: failed to get display params for du=0
[0015.225] W> "reset" doesn't exist, creating
[0015.229] I> Adding ecid(000000016459e587100000000a030240) to DT
[0015.235] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0015.239] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0015.244] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0015.249] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0015.254] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0015.258] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0015.263] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0015.268] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0015.273] W> "misc-data" doesn't exist, creating
[0015.277] I> Boot-device: eMMC
[0015.280] I> Add boot-sdmmc to plugin-manager/misc-data
[0015.285] I> Add storage-sdmmc to plugin-manager/misc-data
[0015.290] W> Unknown storage device
[0015.294] I> Add serial number:1420820014828 as DT property
[0015.300] I> Plugin-manager override starting
[0015.304] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0015.311] I> node /plugin-manager/fragement-soft-wdt matches
[0015.318] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0015.322] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0015.333] I> Disable plugin-manager status in FDT
[0015.334] I> Plugin-manager override finished successfully
[0015.337] I> tegrabl_load_kernel_and_dtb: Done
[0015.341] E> tegrabl_display_clear: display is not initialized
[0015.346] W> Boot logo display failed...
[0015.350] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (1
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 6.448107] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.545636] using random self ethernet address
[ 7.545764] using random host ethernet address
[ 7.755068] random: crng init done
[ 7.755175] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.021423] using random self ethernet address
[ 8.021548] using random host ethernet address
[ 11.429608] Please complete system configuration setup on the serial port pr.
[ 603.837459] edid invalid
��WARNING: pll_d3 has no dyn ramp
Boot didn’t fail. Check the last few lines of the log you posted.
No, the screen stops and only the timer is advancing, as in the first image I posted.
Originally, the warning on the last line would pass immediately after the warning, but here it is stuck and won’t advance for a long time!
The same problem is discussed here, but there is no fundamental solution.
Power on/off is a temporary solution.
Please finish your initial configuration by using ttyACM0 and then share the /var/log/Xorg.0.log.
Your issue is just desktop GUI fails to launch. Not system fails to boot. These two are different.
Is there a website with specific instructions on how to do this?
Connect the flash type C port between your host and jetson. After the board is successfully flashed, there would be a /dev/ttyACM0 node on your host side. Use console tool to open it with baud rate 115200.
And you will see the screen as the document.
Finish the user configuration and your uart will be boot into system. After boot into system, share me the log I need.
