Fake sink group id
• DeepStream Version
• TensorRT Version
I am facing the following FIXME issue.
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source_bin 1
Creating source_bin 2
Creating source_bin 3
Creating source_bin 4
Creating Tee
Creating nvstreamdemux
vehiclecount defaultdict(<class ‘list’>, {‘vehiclecount’: [0, 3, 4], ‘face’: [1, 2]})
LINKINGGGGGG 0
LINKINGGGGGG 3
LINKINGGGGGG 4
face defaultdict(<class ‘list’>, {‘vehiclecount’: [0, 3, 4], ‘face’: [1, 2]})
LINKINGGGGGG 1
LINKINGGGGGG 2
Creating the pgie
Creating FakeSink
Creating the pgie
Creating FakeSink
Saving pipeline graph in folder /opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/deepstream_flow
VEHICCCCCCCCCCC
VEHICCCCCCCCCCC
0:00:01.591490712 2061 0x221df60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/age_googlenet1.caffemodel_b16_gpu0_fp32.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x224x224
1 OUTPUT kFLOAT loss3/classifier_agexgender 8x1x1
ERROR: [TRT]: 3: Cannot find binding of given name: loss3/loss3
0:00:01.621607754 2061 0x221df60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 2]: Could not find output layer ‘loss3/loss3’ in engine
0:00:01.622134170 2061 0x221df60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/age_googlenet1.caffemodel_b16_gpu0_fp32.engine
0:00:01.623174254 2061 0x221df60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 2]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/deepstream_flow/face.txt sucessfully
0:00:01.623232042 2061 0x221df60 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1170> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:02.287340053 2061 0x221df60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.312491994 2061 0x221df60 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
0:00:02.313024530 2061 0x221df60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/deepstream_tao_apps/apps/tao_detection/deepstream_flow/vehiclecount.txt sucessfully
0:00:02.346172603 2061 0x7f26fc034de0 FIXME default gstutils.c:3980:gst_pad_create_stream_id_internal:fakesrc0:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.353253005 2061 0x7f26f4003920 FIXME default gstutils.c:3980:gst_pad_create_stream_id_internal:fakesrc1:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.356843261 2061 0x7f26e8003b60 FIXME default gstutils.c:3980:gst_pad_create_stream_id_internal:fakesrc2:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.474427825 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474456238 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.474464862 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474469072 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.474479747 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474485606 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat AV10
0:00:02.474490911 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474498166 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat AV10
0:00:02.474508047 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474514428 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX5
0:00:02.474517717 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474522929 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX5
0:00:02.474532120 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474537745 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat DVX4
0:00:02.474541360 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474545111 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat DVX4
0:00:02.474551153 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474557829 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.474560957 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474564676 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.474570732 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474576101 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.474579368 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474584528 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.474590948 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474596270 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:02.474602830 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474611013 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:02.474621466 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474630553 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.474635920 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474644075 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.474654780 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474660425 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.474663484 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474670577 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.474686583 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474696443 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:02.474702344 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.474720297 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:02.474952893 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.474966708 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:02.474975709 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.474981664 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:02.474991168 2061 0x7f26fc0356a0 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f268c0897d0 Failed to determine interlace mode
0:00:02.534112448 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534136093 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.534140956 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534148744 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.534159068 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534164708 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat AV10
0:00:02.534170171 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534175486 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat AV10
0:00:02.534182717 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534188324 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat DVX5
0:00:02.534197318 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534204812 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat DVX5
0:00:02.534217968 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534224284 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat DVX4
0:00:02.534229363 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534234514 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat DVX4
0:00:02.534240677 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534246169 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.534250805 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534256096 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.534261930 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534268239 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.534273446 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534277020 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.534286428 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534294052 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:02.534297238 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534302069 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:02.534319588 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534324002 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.534327191 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534330772 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.534336003 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534340015 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.534343536 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534348844 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.534357863 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534365251 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:02.534372799 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.534393221 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:02.534419937 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.534427550 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:02.534432846 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.534436410 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:02.534448510 2061 0x7f269001cc60 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f2674058770 Failed to determine interlace mode
0:00:02.579718888 2061 0x7f26fc0356a0 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<fakesink_vehiclecount> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.579749748 2061 0x7f26fc0356a0 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<fakesink_face> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.580033437 2061 0x7f26fc0356a0 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.580055333 2061 0x7f26fc0356a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.580641537 2061 0x7f268c013980 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:02.606012217 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606030401 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.606034741 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606041380 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.606051678 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606059087 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat AV10
0:00:02.606062591 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606069237 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat AV10
0:00:02.606083239 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606092243 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat DVX5
0:00:02.606099738 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606105127 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat DVX5
0:00:02.606120083 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606130480 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat DVX4
0:00:02.606136656 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606144797 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat DVX4
0:00:02.606156056 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606164553 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.606172443 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606178047 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.606190248 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606199115 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.606206436 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606224868 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.606239813 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606248168 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H265
0:00:02.606255940 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606262557 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H265
0:00:02.606275321 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606284420 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.606292010 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606299959 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.606324796 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606336106 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.606344410 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606352229 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.606364134 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606372458 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe minimum capture size for pixelformat H264
0:00:02.606379936 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:sink Unable to try format: Unknown error -1
0:00:02.606385388 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:sink Could not probe maximum capture size for pixelformat H264
0:00:02.606406780 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:02.606413888 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe minimum capture size for pixelformat NM12
0:00:02.606417608 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder2:src Unable to try format: Unknown error -1
0:00:02.606422897 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder2:src Could not probe maximum capture size for pixelformat NM12
0:00:02.606429247 2061 0x7f26740105e0 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f266c071010 Failed to determine interlace mode
0:00:02.639257366 2061 0x7f269001cc60 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<fakesink_vehiclecount> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.639287648 2061 0x7f269001cc60 FIXME basesink gstbasesink.c:3246:gst_base_sink_default_event:<fakesink_face> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:02.639952830 2061 0x7f269001cc60 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.639968442 2061 0x7f269001cc60 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.640842687 2061 0x7f267400fcc0 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
Current Frame Information: [array(, shape=(0, 0, 4), dtype=uint8)] <pyds.NvDsBatchMeta object at 0x7f27fd63ca30> [<pyds.NvDsFrameMeta object at 0x7f27f89c5270>] [[<pyds.NvDsObjectMeta object at 0x7f27f89d01b0>, <pyds.NvDsObjectMeta object at 0x7f27f89d0230>, <pyds.NvDsObjectMeta object at 0x7f27f89d02b0>, <pyds.NvDsObjectMeta object at 0x7f27f89d0330>]]
NUMMMMMMMMMMMM 4 VEHICLE COUNTTT
OBJJJJJJ METAAAAAA 2 18446744073709551615 0.5322265625 67.8662109375 Person
OBJJJJJJ METAAAAAA 2 18446744073709551615 0.2822265625 72.54345703125 Person
OBJJJJJJ METAAAAAA 2 18446744073709551615 0.2081298828125 272.3994140625 Person
OBJJJJJJ METAAAAAA 3 18446744073709551615 0.203369140625 1863.3369140625 Roadsign
0:00:02.772249024 2061 0x7f26ec003a40 FIXME default gstutils.c:3980:gst_pad_create_stream_id_internal:fakesrc3:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.773568157 2061 0x7f26f00035e0 FIXME default gstutils.c:3980:gst_pad_create_stream_id_internal:fakesrc4:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:02.909258374 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909276989 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.909281386 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909285070 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.909296751 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909312273 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat AV10
0:00:02.909315970 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909319923 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat AV10
0:00:02.909327628 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909334512 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat DVX5
0:00:02.909337794 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909341601 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat DVX5
0:00:02.909348119 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909353644 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat DVX4
0:00:02.909356889 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909362266 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat DVX4
0:00:02.909369565 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909375155 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.909380266 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909383621 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.909395014 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909400588 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.909404314 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909408203 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.909415264 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909418802 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H265
0:00:02.909432230 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909435954 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H265
0:00:02.909442097 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909445591 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.909451416 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909456477 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.909463550 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909476151 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.909483864 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909487404 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.909493836 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909497242 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe minimum capture size for pixelformat H264
0:00:02.909500505 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:sink Unable to try format: Unknown error -1
0:00:02.909503837 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:sink Could not probe maximum capture size for pixelformat H264
0:00:02.909533508 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:02.909554658 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe minimum capture size for pixelformat NM12
0:00:02.909562848 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder3:src Unable to try format: Unknown error -1
0:00:02.909569674 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder3:src Could not probe maximum capture size for pixelformat NM12
0:00:02.909578515 2061 0x7f26f4003060 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f26d807d090 Failed to determine interlace mode
0:00:02.922052604 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922072646 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.922076907 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922083986 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.922100509 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922110127 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat AV10
0:00:02.922118371 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922126241 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat AV10
0:00:02.922138886 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922149280 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat DVX5
0:00:02.922159261 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922167544 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat DVX5
0:00:02.922180778 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922190864 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat DVX4
0:00:02.922198746 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922204624 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat DVX4
0:00:02.922215822 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922224571 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.922232630 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922242097 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.922255760 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922262244 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.922267264 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922275727 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.922292914 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922302138 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat H265
0:00:02.922307697 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922325109 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat H265
0:00:02.922339431 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922349962 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.922357538 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922365825 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.922375564 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922385558 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.922395058 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922404487 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.922416516 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922423852 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe minimum capture size for pixelformat H264
0:00:02.922431341 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:sink Unable to try format: Unknown error -1
0:00:02.922439418 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:sink Could not probe maximum capture size for pixelformat H264
0:00:02.922475196 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:src Unable to try format: Unknown error -1
0:00:02.922489166 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:src Could not probe minimum capture size for pixelformat NM12
0:00:02.922498510 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:nvv4l2decoder4:src Unable to try format: Unknown error -1
0:00:02.922506297 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder4:src Could not probe maximum capture size for pixelformat NM12
0:00:02.922517082 2061 0x7f264401f800 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f26d00b6550 Failed to determine interlace mode
^C0:01:38.273712897 2061 0x1a5c120 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Unhandled error
0:01:38.273739298 2061 0x1a5c120 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Option not supported (551)
0:01:38.273780099 2061 0x1a5c120 WARN rtspsrc gstrtspsrc.c:8669:gst_rtspsrc_pause: error: Could not send message. (Generic error)
0:01:38.273779736 2061 0x1ce87000 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Unhandled error
0:01:38.273802864 2061 0x1ce87000 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Option not supported (551)
0:01:38.273820640 2061 0x1ce87000 WARN rtspsrc gstrtspsrc.c:8669:gst_rtspsrc_pause: error: Could not send message. (Generic error)
0:01:38.274819159 2061 0x20ec3060 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Unhandled error
0:01:38.274837236 2061 0x20ec3060 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Option not supported (551)
0:01:38.274866124 2061 0x20ec3060 WARN rtspsrc gstrtspsrc.c:8669:gst_rtspsrc_pause: error: Could not send message. (Generic error)
0:01:38.277344278 2061 0x221c5e0 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Unhandled error
0:01:38.277371166 2061 0x221c5e0 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Option not supported (551)
0:01:38.277408818 2061 0x221c5e0 WARN rtspsrc gstrtspsrc.c:8669:gst_rtspsrc_pause: error: Could not send message. (Generic error)
0:01:38.277853183 2061 0x1ce87240 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Unhandled error
0:01:38.277879971 2061 0x1ce87240 WARN rtspsrc gstrtspsrc.c:6585:gst_rtspsrc_send: error: Option not supported (551)
0:01:38.277900231 2061 0x1ce87240 WARN rtspsrc gstrtspsrc.c:8669:gst_rtspsrc_pause: error: Could not send message. (Generic error)
0:01:38.288901500 2061 0x7f26e80040c0 WARN rtpjitterbuffer rtpjitterbuffer.c:587:calculate_skew: delta - skew: 0:00:01.181121885 too big, reset skew
0:01:38.289113201 2061 0x7f26f4003060 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:01:38.289113689 2061 0x7f264401f800 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:01:38.289116669 2061 0x7f26740105e0 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:01:38.289150033 2061 0x7f264401f800 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder4:pool:src Uncertain or not enough buffers, enabling copy threshold
0:01:38.289133661 2061 0x7f26f4003060 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder3:pool:src Uncertain or not enough buffers, enabling copy threshold
0:01:38.289169249 2061 0x7f26740105e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:nvv4l2decoder2:pool:src Uncertain or not enough buffers, enabling copy threshold
0:01:38.289361152 2061 0x7f26fc034f00 WARN rtpjitterbuffer rtpjitterbuffer.c:587:calculate_skew: delta - skew: 0:00:04.972253404 too big, reset skew
0:01:38.289523456 2061 0x7f26f0003700 WARN rtpjitterbuffer rtpjitterbuffer.c:587:calculate_skew: delta - skew: 0:00:06.000696909 too big, reset skew
0:01:38.290335876 2061 0x7f26d8010240 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder3:pool:src Driver should never set v4l2_buffer.field to ANY
0:01:38.290522923 2061 0x7f26d0010800 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder4:pool:src Driver should never set v4l2_buffer.field to ANY
0:01:38.314161061 2061 0x7f268c013980 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.621765406 < 0:00:00.849698326)
0:01:38.314226288 2061 0x7f26fc0356a0 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.698072025 < 0:00:00.849698326)
0:01:38.314301316 2061 0x7f26fc0356a0 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.736041928 < 0:00:00.849698326)
0:01:38.314356079 2061 0x7f26fc0356a0 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.773940010 < 0:00:00.849698326)
0:01:38.314388400 2061 0x7f26fc0356a0 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.811810124 < 0:00:00.849698326)
0:01:38.321969101 2061 0x7f267400fcc0 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.644688538 < 0:00:00.873483456)
0:01:38.322005016 2061 0x7f269001cc60 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.721337087 < 0:00:00.873483456)
0:01:38.322053708 2061 0x7f269001cc60 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.759464130 < 0:00:00.873483456)
0:01:38.322105553 2061 0x7f269001cc60 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.797503917 < 0:00:00.873483456)
0:01:38.322150917 2061 0x7f269001cc60 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.835496081 < 0:00:00.873483456)
0:01:38.344519879 2061 0x7f26d0010800 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.781483805 < 0:00:01.016140901)
0:01:38.344608248 2061 0x7f264401f800 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.860463054 < 0:00:01.016140901)
0:01:38.344687041 2061 0x7f264401f800 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.899687353 < 0:00:01.016140901)
0:01:38.344748938 2061 0x7f264401f800 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.938713425 < 0:00:01.016140901)
0:01:38.344805591 2061 0x7f264401f800 WARN videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame: decreasing timestamp (0:00:00.977532017 < 0:00:01.016140901)
0:01:38.346787250 2061 0x7f26f0003700 WARN rtpjitterbuffer rtpjitterbuffer.c:587:calculate_skew: delta - skew: 0:00:04.783400456 too big, reset skew
Please share the platform type and deepstream/cuda/driver version information as mentioned at the beginning of the description, and please also share the command to start the program. In case it is your own customized program, please share your pipeline, thank you.
Here is my program!
I am trying to implement the parallel model inferencing in python.
Can you please check and let me know if, the elements added and linked are correct, and what else am I missing that is giving me the above error.
clean_code.py (20.5 KB)
GPU
6.1.
tensorrt 8.4.1.5
| NVIDIA-SMI 525.78.01 Driver Version: 525.78.01 CUDA Version: 12.0
I can see that the create_source_bin function creates h264 parse, and encoder for a h265 stream. Do you think this can be causing the error? If so how do I fix it?
  1. from the pipeline graph, why is there h264 parse and encoder?
  2. from the logs, most of them are warning logs, can application run?
If you look at my code, the “_create_source_bin” function is taking care of it.
So then, is my “_create_source_bin” function wrong?
These are the same functions from all the deepstream-python-apps, correct me if I am wrong!
There is a FIXME, can you please look into that!
  1. create_source_bin will decode input , it will not create encoder.
  2. what is the input type? why is there fakesrc?
  3. to narrow down this issue, you can remove the middle plugins, only debug src+sink.
what about these?
Decode nameee decodebin3
Decode nameee rtph264depay3
Decode nameee h264parse3
Decode nameee capsfilter3
Decode nameee nvv4l2decoder3
i need all of the h264 in h265
There is a parser!
The input is an “rtsp source”, there is only a fake sink. If you look into my code you would understand better… There is an rtsp source and a fake sink.
Are you expecting this??
I don’t know what is causing this issue, that’s why I reached out to the Forum, you should have a better understanding in what is causing the issue…
You even asked me to share my pipeline, I did… Now, if you are questioning me, it doesn’t really make sense.
  1. I don’t know about your code, please debug the custom code by simplifying the code.
  2. the official samples has no this kind of problems, you can compare the pipeline graph, there is a rtsp input sample: https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/apps/deepstream-demux-multi-in-multi-out, and there is a parallel inference sample: deepstream_parallel_inference_app
I am using this as a reference to create my custom code. That is what I had mentioned earlier.
That is why I reached out to the Forum since, I followed the official samples, and my custom was giving issues.
No worries, if you are unable to provide a solution, by taking all the inputs.
I had built everything by creating small blocks, and adding subsequent blocks when everything was fine.
