I am getting this error in kernel log:
kernel: [ 6.918097] FAN: coudln’t get the regulator
As a result pwm_fan is not probing and /sys/kernel/debug/tegra_fan/target_pwm is missing.
What could make “vdd-fan” regulator to disappear?
L4T 24.1, kernel cmdline:
panic=10 fbcon=map:0 console=tty0 console=ttyS0,115200n8 tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt root=/dev/mmcblk1p1 rw rootwait noplymouth text
Hi DmitriK,
let us check fan regulator issue step by step.
The error message “FAN: coudln’t get the regulator” should come from
drivers/thermal/pwm_fan.c:842 like the lines below and because something wrong at line 840,
you just return from line 844 and does not run the remaining lines of pwm_fan_probe to cause /sys/kernel/debug/tegra_fan/target_pwm is missing.
840 fan_data->fan_reg = regulator_get(fan_data->dev, “vdd-fan”);
841 if (IS_ERR_OR_NULL(fan_data->fan_reg)) {
842 pr_err(“FAN: coudln’t get the regulator\n”);
843 devm_kfree(&pdev->dev, (void *)fan_data);
844 return -ENODEV;
845 }
So can you please check your device tree. The following is mine and can be an example.
pwm-fan {
status = "okay";
compatible = "pwm-fan";
shared_data = <0x000000d1>;
active_pwm = <0x00000000 0x000000ff 0x000000ff 0x00002a9a 0x74666573 0x000029f5 0x00002aa9 0x00002ab1 0x00002ac0 0x00002ac6>;
[b]vdd-fan-supply[/b] = <0x000000d2>;
dts looks ok and identical to official dts in this regard. pwm-fan probe function cannot find “vdd_fan” regulator. I am using own custom carrier board that provides 5V to fan.
Could it be that power tree initialization went bad because module is used in non-devkit carrier?
Does devkit really use this regulator to power the fan?
vdd_fan: regulator@13 {
compatible = “regulator-fixed-sync”;
reg = <13>;
regulator-name = “vdd-fan”;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&gpio ((4 * 8) + 4) 0>;
regulator-enable-ramp-delay = <284>;
regulator-disable-ramp-delay = <6200>;
gpio = <&tca9539_74 4 0>;
regulators I have:
regulator-dummy
vdd-cam-hv
vdd-rtc
avdd-ts-hv
vdd-ts
vdd-gen-pll-edp
vdd-hdmi-dp
vdd-3v3
max77620-gpio7
lcd-bl-en
en-vdd-sd
vdd-ac-bat
vdd-sys-boost
aux-3v3
snsr_pm
vdd-disp-3v0
usb-vbus1
usb-vbus3
rtl-5v0
en-usb-vbus2
en-vdd-vcm-2v8
vdd_gpu
vdd-cpu-fixed
vdd_cpu
vdd_core
vddio-ddr
vdd-pre-reg
vdd-1v8
avdd-sys
vdd-pex
vddio-sdmmc1
Does your design use tca9539 to control the fan?
Yes, device driver pwm-fan use vdd-fan to power the fan via calling regulater_xxx() and like your check,
I don’t see vdd-fan in cat /sys/class/regulator/regulator.*/name. This is weird.
So could you help to
Hi Ted,
I’ve been helping Dmitri with the tegra hardware. I’ve been looking at your schematics for this circuit.
I’ll go ahead an attach a screen shot of your schematics for reference.
As far as I can tell, the fan is powered of of 5V0_IO_SYS. This is powered on and off via carrier_power_on which is asserted at boot. I don’t see any other IO controlling this rail from the X1 SOM itself. Am I missing something?
Otherwise, you do have 3 other fan related signals:
FAN_PWM - 1.8 VDC PWM signal coming off the tegra itself.
PS_VDD_FAN_DISABLE- This is coming off the tca9539 on your carrier board. Asserting this high is effectively voiding the PWM signal coming out of the X1 SOM. This isn’t a power supply per se, but it might be what your VDD-FAN device driver is trying to assert?
FAN_TACH - This is the one output from the Fan itself. I believe its the feedback your SOM is likely using to do speed control on the fan itself.
Can you clarify what the call to regulator_xxx() is actually doing? What, if anything is it controlling?
Thanks for your help Ted!
Doug
Ted,
Answering your questions:
- check if the values of vdd-fan-supply are same as expected by sudo hexdump /proc/device-tree/pwm-fan/vdd-fan-supply
root@jane:/var/log# hexdump /proc/device-tree/pwm-fan/vdd-fan-supply
0000000 0000 bc00
0000004
- check what is the error return value of regulator_get(fan_data->dev, “vdd-fan”) by printk …
[ 7.647183] FAN: coudln’t get the regulator vdd-fan ERR: -517
pr_err(“FAN: coudln’t get the regulator %s ERR: %d\n”, “vdd-fan”, (int)PTR_ERR(fan_data->fan_reg));
return -ENODEV;
Yes, vdd-fan is binding to the pin PS_VDD_FAN_DISABLE as a regulator via device tree like in #4.
and the device tree looks okay to me. But according to the error return value -517, it’s more like
something wrong on tca9539.
#define EPROBE_DEFER 517 /* Driver requests probe retry */
and I re-checked the list in #5. does not see those regulators which are binding to tca9539 like en_vdd_ts_1v8 or en_vdd_ts_hv_3v3.
so maybe all the regulators related to tca9539 also do not work properly.
Could you help to check tca9539 as following.
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074$ ls
driver gpio modalias name power subsystem uevent
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074$ cat name
tca9539
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074$ cd gpio/gpiochip1008/
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074/gpio/gpiochip1008$ ls
base device label ngpio power subsystem uevent
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074/gpio/gpiochip1008$ cat label
tca9539
ubuntu@tegra-ubuntu:/sys/devices/platform/7000c400.i2c/i2c-1/1-0074/gpio/gpiochip1008$ cat ngpio
16
tca9539 & PS_VDD_FAN_DISABLE were removed from our HW design. I am going to replace vdd_fan by dummy regulator.
tca9539 & PS_VDD_FAN_DISABLE were removed from our HW design. Need to replace vdd_fan by dummy regulator.
OK. You can just remove the following code snippet from your device tree
210 vdd_fan: regulator@13 {
211 gpio = <&tca9539_74 4 0>;
212 };
to binding vdd-fan with PS_VDD_FAN_DISABLE as a tegra’s gpio not tca9539’s gpio.
then you should be able to see vdd-fan from the list in #5. and don’t forget to modify
the property gpio accroding to your HW design.
166 vdd_fan: regulator@13 {
167 compatible = “regulator-fixed-sync”;
168 reg = <13>;
169 regulator-name = “vdd-fan”;
170 regulator-min-microvolt = <5000000>;
171 regulator-max-microvolt = <5000000>;
172 gpio = <&gpio TEGRA_GPIO(E, 4) 0>;
173 regulator-enable-ramp-delay = <284>;
174 regulator-disable-ramp-delay = <6200>;
175 };
Our HW folks just dropped FAN_DISABLE feature completely from design - there is no gpio to bind for this.
I added dummy regulator to resolve this issue:
— a/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
+++ b/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
@@ -129,4 +129,20 @@
pwm-fan {
vdd-fan-supply = <&vdd_fan_dummy>;
regulators {
compatible = "simple-bus";
vdd_fan_dummy: regulator-dummy {
compatible = "regulator-fixed";
regulator-name = "vdd-fan";
