Fan options on Orin AGX Development kit module + Third-Party Carrier Board
I have an Orin AGX developer kit. My team has decided to switch out the carrier board for a reComputer mini-J501. Problem is, the mini-J501 uses 12V PWM for its fan connector, whereas the dev kit fan uses 5V PWM.
Unfortunately, I won’t be able to swap out either the module or the carrier board for the foreseeable future.
I’m looking for help to figure out what route I should go down. The simplest option I could think of was to just swap out the fan with the intended one for this carrier board, but I’ve heard that you’re not supposed to disassemble the module-fan assembly on developer kits.
Is replacing the fan my best bet here? Did I read the datasheets wrong? Are there other options I’m not considering?
Thanks in advance!
The fan connector specification is determined by the carrier board design.
Please contact the carrier board manufacture (Seeed Studio) for compatible fan options for the reComputer mini-J501.
Thank you,
Got it, will do. We’ve just recently realized that the fan on the developer kit module is easily removable, so we’ll just be replacing it with a standard 12V PVM fan. Apologies for the trouble.
