In my code, I will set /sys/devices/pwm-fan/target_pwm to adjust the fan speed. But I found after my code set /sys/devices/pwm-fan/target_pwm, this fan pwm won’t be changed again, even the temperature is down to very low like 30C. I suppose the fan should stop( fan PWM = 0) when temperature is down to 35C. Fan mode is cool mode.
Is this NX devkit or some custom board?
It is NX devkit.
Which JetPack version
Jetpack 4.6 [L4T 32.6.1]
