Note that jetpack packages are not installed. You may try installing these.
Do you see any service having failed to start ?
sudo systemctl --failed
You may also try to reinstall bootloader with:
sudo dpkg-reconfigure nvidia-l4t-bootloader
If not enough, you may post the output of:
cat /etc/nv_boot_control.conf
That does sound like a problem.
$ sudo apt update && sudo apt install nvidia-jetpack
Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Get:2 https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/arm64 InRelease [1 484 B]
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:6 https://download.docker.com/linux/ubuntu focal InRelease
Hit:7 https://repo.download.nvidia.com/jetson/common r35.1 InRelease
Hit:8 https://repo.download.nvidia.com/jetson/t234 r35.1 InRelease
Hit:9 https://install.husarnet.com/deb all InRelease
Fetched 1 484 B in 11s (140 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
9 packages can be upgraded. Run 'apt list --upgradable' to see them.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-jetpack : Depends: nvidia-jetpack-runtime (= 5.0.2-b231) but it is not going to be installed
Depends: nvidia-jetpack-dev (= 5.0.2-b231) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Upgrading the 9 packages does not solve anything, nor does running sudo apt install --fix-broken
, or disc-upgrade
, or any other command found in How to Install JetPack :: NVIDIA JetPack Documentation. Perhaps this is interesting:
$ grep -nwr "nvidia" /etc/apt/sources.list.d/
/etc/apt/sources.list.d/nvidia-container-toolkit.list:1:deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/$(ARCH) /
/etc/apt/sources.list.d/nvidia-container-toolkit.list:2:#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://nvidia.github.io/libnvidia-container/experimental/ubuntu18.04/$(ARCH) /
/etc/apt/sources.list.d/nvidia-l4t-apt-source.list:11:deb https://repo.download.nvidia.com/jetson/common r35.1 main
/etc/apt/sources.list.d/nvidia-l4t-apt-source.list:12:deb https://repo.download.nvidia.com/jetson/t234 r35.1 main
I notice that the two final entries look like they should (“r35.1” rather than “35.1”), but what about the first two?
Edit: Haha, forgot to reply to everything except your first line. Here are the outputs.
$ sudo systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
$ sudo dpkg-reconfigure nvidia-l4t-bootloader
Restore link: APP to /dev/nvme0n1p1
Restore link: recovery to /dev/nvme0n1p6
Restore link: recovery-dtb to /dev/nvme0n1p7
Restore link: esp to /dev/nvme0n1p9
3701--0000--1--jetson-agx-orin-devkit-
Starting bootloader post-install procedure.
ERROR. Procedure for bl_only_payload update FAILED.
Cannot install package. Exiting...
Yikes.
$ cat /etc/nv_boot_control.conf
TNSPEC 3701-500-0000-J.0-1-1-jetson-agx-orin-devkit-
COMPATIBLE_SPEC 3701--0000--1--jetson-agx-orin-devkit-
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Apparently installing Nvidia-container before installing jetpack makes jetpack weird. I fixed it, so now
apt list | grep jetpack
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libnvidia-container0/stable,now 0.11.0+jetpack arm64 [installed]
nvidia-jetpack-dev/stable,now 5.0.2-b231 arm64 [installed,automatic]
nvidia-jetpack-runtime/stable,now 5.0.2-b231 arm64 [installed,automatic]
nvidia-jetpack/stable,now 5.0.2-b231 arm64 [installed]
Issue, however, remains, and above post is still correct (ie unable to reconfigure boot loader, no failed services, nv_boot_control.conf unchanged)
hello per.edwardsson,
Jetpack components should be included. could you please also share your full steps to flash AGX Orin. for example, we’re using SDK Manager for setting up development environment and flashing JetPack release image to the target.
Download the files secureboot_R35.1.0_aarch64.tbz2, Jetson_Linux_R35.1.0_aarch64.tbz2, Tegra_Linux_Sample-Root-Filesystem_R351.0_aarch64.tbz2. Untar them in the same folder, in my case ~/nvidia_flash. Since I have an SSD connected on the M2 connector, I would like to utilise that space. I am not sure I have done this step correctly, so feel free to feedback. I find the size of my M2 disk and enter that into the file ./tools/kernel_flash/flash_lft_nvme.xml
, in row 2, setting sector_size
and num_sectors
to match my disk. I then do sudo ./apply_binaries.sh
. I also did sudo ./tools/l4t_create_default_user.sh
to create a user. I then perform the flashing in two steps. First, I run sudo ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash -c tools/kernel_flash/flash_l4t_nvme.xml --external_device nvme0n1p1 --showlogs -S 450GiB jetson-agx-orin-devkit nvme0n1p1
. After that completes, I replace --no-flash
with --flash-only
. Sometimes I have to retry once or twice before succeeding, which is why I split it up.
From now, fan is on. Any advice?
could you please also confirm by using SDK Manager for setting up development environment and flashing JetPack release image to the target.
