Fan set cool perfile
Fan set cool perfile on orin NX,Thanks
We don’t know what your requirement at this posting.
Please continue updating on your orignal topic: Fan speed on AGX Orin - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
改成如下设置,我发用quiet模式pwm最大只有97,风扇转速无法达到最大100%
Hi sorry.shao,
Are you using the devkit or custom board for Orin NX?
Do you want to use quiet mode with pwm 100%?
Have you tried to use sysfs to control and check current pwm/rpm?
custom board
Do you want to use quiet mode or other mode with pwm 100% ?
Have you tried to use sysfs to control and check current pwm/rpm? yes
Could you help to check if the following command meet your requirement?
$ sudo su
# systemctl stop nvfancontrol
# echo 255 > /sys/devices/platform/pwm-fan/hwmon/hwmon2/pwm1
If not, please help to clarify what’s your requirement.
