Devkit board Fan can correctly identify the speed,but Custom board fan can not correctly identify the speed.
Can you help to provide the information about the speed of the Devkit board Fan,Thanks
Hi sorry.shao,
Could you share result of the following command on your board?
$ ls -l /sys/class/hwmon/
Do you have any custom design for the fan different from the devkit?
是风扇的差异导致。所以我们想参考一下开发板的风扇,所以找您们要一下开发板风扇转速的资料,感谢
For the fan from the devkit, the rpm is 2900 ± 10% R.P.M.
How about yours?
Have you tried using the fan from devkit on your custom carrier board and it could work?
Is this still an issue to support? Any result can be shared? Thanks
