Fan speed regression with NVIDIA beta 470.42.01 and RTX 3080 (fans don't stop on idle)
Please test with driver 520.56.06 which has the fix and share results.
We have updated the nvidia-settings control panel to correctly limit the allowed values for GPUTargetFanSpeed to match the existing valid fan speed ranges for supported NVIDIA GPUs. The valid ranges are 30%-100% for Ampere or newer GPUs, and 1%-100% for older GPUs.
Doesn’t this break zero RPM mode for Pascal GPUs?
Thanks @amrits, it does work as you describe.
The Xorg/root looks solved as well.
But: it would be great if 0%/fan stop could be allowed as well.
The GPU fan may stop when the temperature is low enough, but only when the fan speed is under GPU control. For safety reasons, there is a minimum fan speed enforced when the fan speed is under user control
