Assume I have two matrices A and B of the shape n * m. I want to calculate an n * n matrix C, such that C[i,j]=||A[i]-B[j]||
where || || is a distance measure for two vectors, such as the infinity-norm distance (max absolote distance) or the Manhattan distance (sum of absolute distance). I have write a CUDA kernel using the approach based on shared memory described in CUDA best practice guide as follows:
#define TILE_DIM 16
// Assuming N and M are multiples of TILE_DIM for simplicity
__global__ void cross_infinity_norm(float *a, float* b, float *c, int N, int M)
__shared__ float aTile[TILE_DIM][TILE_DIM], bTile[TILE_DIM][TILE_DIM + 2];
int a_row_block = blockIdx.y * TILE_DIM + threadIdx.y;
int b_row_block = blockIdx.x * TILE_DIM + threadIdx.x;
float ans = 0.0f;
for (int i = 0; i < M; i += TILE_DIM) {
aTile[threadIdx.y][threadIdx.x] = a[(blockIdx.y * TILE_DIM + threadIdx.y) * N + i + threadIdx.x];
bTile[threadIdx.x][threadIdx.y] = b[(blockIdx.x * TILE_DIM + threadIdx.y) * N + i + threadIdx.x];
__syncthreads();
#pragma unroll
for (int j = 0; j < TILE_DIM; j++)
ans = max(ans, abs(aTile[threadIdx.y][j] - bTile[j][threadIdx.x]));
__syncthreads();
c[a_row_block * N + b_row_block] = ans;
In my opinion, this program is efficient since it has no bank conflict of shared memory and all global memory accesses are coalesced. However, when I profile this program using NVIDIA Nsight Compute (setting N = M = 2048), it shows the following output with two warnings:
DRAM Frequency cycle/nsecond 9.49
SM Frequency cycle/nsecond 1.39
Elapsed Cycles cycle 10,142,211
Memory [%] % 96.97
SOL DRAM % 32.92
Duration msecond 7.27
SOL L1/TEX Cache % 97.14
SOL L2 Cache % 28.21
SM Active Cycles cycle 10,120,031.15
SM [%] % 96.97
OK The kernel is utilizing greater than 80.0% of the available compute or memory performance of the device. To
further improve performance, work will likely need to be shifted from the most utilized to another unit.
Start by analyzing workloads in the Compute Workload Analysis section.
OK The ratio of peak float (fp32) to double (fp64) performance on this device is 64:1. The kernel achieved 4% of
this device's fp32 peak performance and 0% of its fp64 peak performance.
Section: Compute Workload Analysis
Executed Ipc Active inst/cycle 1.41
Executed Ipc Elapsed inst/cycle 1.40
Issue Slots Busy % 35.17
Issued Ipc Active inst/cycle 1.41
SM Busy % 35.17
Section: Memory Workload Analysis
Memory Throughput Gbyte/second 300.02
Mem Busy % 62.33
Max Bandwidth % 96.97
L1/TEX Hit Rate % 0.27
L2 Compression Success Rate % 0
L2 Compression Ratio 0
L2 Hit Rate % 49.69
Mem Pipes Busy % 96.97
Section: Scheduler Statistics
One or More Eligible % 35.18
Issued Warp Per Scheduler 0.35
No Eligible % 64.82
Active Warps Per Scheduler warp 11.86
Eligible Warps Per Scheduler warp 1.64
WRN Every scheduler is capable of issuing one instruction per cycle, but for this kernel each scheduler only
issues an instruction every 2.8 cycles. This might leave hardware resources underutilized and may lead to
less optimal performance. Out of the maximum of 12 warps per scheduler, this kernel allocates an average of
11.86 active warps per scheduler, but only an average of 1.64 warps were eligible per cycle. Eligible warps
are the subset of active warps that are ready to issue their next instruction. Every cycle with no eligible
warp results in no instruction being issued and the issue slot remains unused. To increase the number of
eligible warps either increase the number of active warps or reduce the time the active warps are stalled.
Section: Warp State Statistics
Warp Cycles Per Issued Instruction cycle 33.72
Warp Cycles Per Executed Instruction cycle 33.72
Avg. Active Threads Per Warp 32
Avg. Not Predicated Off Threads Per Warp 31.98
WRN On average each warp of this kernel spends 15.9 cycles being stalled waiting for the MIO instruction queue to
be not full. This represents about 47.2% of the total average of 33.7 cycles between issuing two
instructions. This stall reason is high in cases of extreme utilization of the MIO pipelines, which include
special math instructions, dynamic branches, as well as shared memory instructions.
Section: Instruction Statistics
Avg. Executed Instructions Per Scheduler inst 3,559,324.10
Executed Instructions inst 1,167,458,304
Avg. Issued Instructions Per Scheduler inst 3,559,430.27
Issued Instructions inst 1,167,493,130
Section: Launch Statistics
Block Size 256
Grid Size 16,384
Registers Per Thread register/thread 36
Shared Memory Configuration Size Kbyte 32.77
Driver Shared Memory Per Block Kbyte/block 1.02
Dynamic Shared Memory Per Block byte/block 0
Static Shared Memory Per Block Kbyte/block 2.18
Threads thread 4,194,304
Waves Per SM 33.30
Section: Occupancy
Block Limit SM block 16
Block Limit Registers block 6
Block Limit Shared Mem block 32
Block Limit Warps block 6
Theoretical Active Warps per SM warp 48
Theoretical Occupancy % 100
Achieved Occupancy % 98.84
Achieved Active Warps Per SM warp 47.44
(My GPU is NVIDIA RTX 3090.)
The test program is as follows:
int main() {
int N = 2048, M = 2048;
float *output = new float[N * N];
float *input = new float[N * M];
float *weight = new float[N * M];
for (int i = 0; i < N * M; i++)
input[i] = ((float)rand() - 0.5) / RAND_MAX;
weight[i] = ((float)rand() - 0.5) / RAND_MAX;
float *input_cuda, *weight_cuda, *output_cuda;
cudaMalloc(&output_cuda, N * N * sizeof(float));
cudaMalloc(&input_cuda, N * M * sizeof(float));
cudaMalloc(&weight_cuda, N * M * sizeof(float));
cudaMemcpy(input_cuda, input, N * M * sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(weight_cuda, weight, N * M * sizeof(float), cudaMemcpyHostToDevice);
for (int i = 0; i < 2; i++) {
dim3 dimBlock(TILE_DIM, TILE_DIM);
dim3 dimGrid(N / TILE_DIM, N / TILE_DIM);
cross_infinity_norm<<<dimGrid, dimBlock>>>(input_cuda, weight_cuda, output_cuda, N, M);
cudaDeviceSynchronize();
cudaFree(output_cuda);
cudaFree(input_cuda);
cudaFree(weight_cuda);
delete[] output;
delete[] input;
delete[] weight;
In particular, I am confused by the profiler output that the program should improve the Compute Workload, but the above warning says the stall reason is high in cases of extreme utilization of the MIO pipelines, which include special math instructions, dynamic branches, as well as shared memory instructions. My questions are:
- How can I understand the profiler output? In particular, what does the two warnings mean? (This program does not have special math instructions or dynamic branches.)
- Is there a faster implementation? I really want an extremely fast implementation since this function will be run thousands of times. Any tricks or achitecture dependent optimizations (NVIDIA RTX 3090 with Compute Capability 8.6 in my case) can be used.
