Fast device memcpy for irregular datatypes
I had a simple memcpy routine built in before that was templated on the type being copied that worked well for basic data types like ints, floats, etc. I also used it on complex data types like classes as well. However, I recently noticed that performance took a 10x or so hit when using classes with more than one data member such as:
[codebox]template< typename T >
global void memcpy( T* out, const T* in, unsigned int size )
if( GLOBAL_ID() >= size )
	return;
switch( sizeof( T ) )
	case 8:
		uint2* _out = ( uint2* ) out;
		uint2* _in = ( uint2* ) in;
		_out[ GLOBAL_ID() ] = _in[ GLOBAL_ID() ];
		break;
	case 16:
		uint4* _out = ( uint4* ) out;
		uint4* _in = ( uint4* ) in;
		break;
	default:
		const unsigned int mod4 = sizeof( T ) % 4;
		const unsigned int mod8 = sizeof( T ) % 8;
		const unsigned int mod16 = sizeof( T ) % 16;
		if( mod16 == 0 )
			const unsigned int div16 = sizeof( T ) / 16;
			for( unsigned int i = 0, offset = 0; i != div16; ++i,
				offset += TOTAL_THREADS() )
				_out[ GLOBAL_ID() + offset ] =
					_in[ GLOBAL_ID() + offset ];
		else if( mod8 == 0 )
			const unsigned int div8 = sizeof( T ) / 8;
			for( unsigned int i = 0, offset = 0; i < div8; ++i,
		else if( mod4 == 0 )
			const unsigned int div4 = sizeof( T ) / 4;
			unsigned int* _out = ( unsigned int* ) out;
			unsigned int* _in = ( unsigned int* ) in;
			for( unsigned int i = 0, offset = 0; i < div4; ++i,
		else
			unsigned char* _out = ( unsigned char* ) out;
			unsigned char* _in = ( unsigned char* ) in;
			for( unsigned int i = 0, offset = 0; i < sizeof( T ); ++i,
		break;
[/codebox]
which seems to get 85-90% of the throughput of the built-in uint2 on irregular classes. Has anyone looked at this in more detail and maybe come up with an even more optimized version that gets closer to the max bandwidth on any data type?
Is there a reason you’re not treating it like a flat array of bytes? I realize you may have to use smaller types if the arrays are misaligned, at least to copy the elements at the beginning and the end. But for the bulk of it, you should be able to use a larger type even if T is just char. Unless the arrays are misaligned relative to each other, in which case you’d have to revert to a size no larger than the relative misalignment, which still may be larger than T. Or shuffle in shared memory.
Alignment issues aside, for high throughput, I assume you have seen dubinsky’s results, which outperform cudaMemcpy?
