I am proud to announce today that the code of “Fast k nearest neighbor search using GPU” is now available.
Indeed, I have received a lot of mails asking me the source code used in the paper “Fast k nearest neighbor search using GPU” presented in the proceedings of the CVPR Workshop on Computer Vision on GPU.
If you plan to use our code, do not forget to cite our paper in your publications.
If you find some optimizations to do or some mistakes, feel free to contact me.
I will try to update the code regularly.
Vincent, thanks for publishing your code. I think this will be a useful tool to many people! :)
If you are going to allow others to use it (and still update it with your own optimizations), why not publish it as an open source project on Google Code (or similar), under a BSD or MIT license? This way, others could make use of it (or even help out with some contributions) without worrying if the project website is going to move around (plus, you can track your source changes and so forth).
Actually, the code is already published under a creative commons license who allows everybody to use and modify the code.
However, your idea (profquail) is very good and we are already looking for the most appropriated website to host our code.
I think we will publish it very soon as an open source project.
In the meantime, I am already working on a new faster version of the code :) .
I just have updated the code. I provide now two implementations of the kNN search to fit to your needs:
[*]With indexes: provides for each query point the distances to the k nearest neighbors and the indexes of these neighbors.
[*]Without indexes: provides for each query point only the distance to the k-th nearest neighbor. This version is faster than the version with indexes because first it uses less memory and second it does not spent time on processing indexes.
The provided CUDA code is usable for C, C++, and Matlab programs. I provide 4 implementations of the kNN search to fit to your needs:
[*] KNN CUDA — implementation CUDA of the k-nearest neighbor search.
[*] KNN CUBLAS — implementation CUBLAS of the k-nearest neighbor search. This version is usually faster than KNN CUDA and is based on matrix multiplication to compute the distances between points.
[*] With indexes — provides for each query point the distances to the k nearest neighbors and the indexes of these neighbors.
[*] Without indexes — provides for each query point only the distance to the k-th nearest neighbor. This version is faster than the version with indexes because first it uses less memory and second it does not spent time on processing indexes.
The CUBLAS version was submitted to ICIP 2010. I hope the reviewers will like my work ;-)
Enjoy my code and feel free to contact me for any question/remark.
Actually, float ssd = 0 will evaluate to float ssd = float(0) where 0 is an integer. It will be a one-time issue of converting an int to a float. If it happens before the main loop, it shouldn’t cause any performance issues. Subsequent uses of ssd will see a float.
The link to the project “Fast k nearest neighbor search using GPU” cited above is not active anymore.
I’ve just created a GitHub repository to host this project. I hope you’ll like it:
“Fast k nearest neighbor search using GPU” will be really useful in clustering algorithms. I would appreciate if you have information about how to compile it on linux.
