Fast math (exp,pwd,log)?
I am using Craypat profiling tools on a code running on a XT5 on 984 cores. The sampling profile gives me the profiling output below. Everything looks quite straightforward and understandable. Some of the routines seem to be quite heavy on the intrinsic EXP, POW and LOG functions. Is there any way to try out optimized/accelerated maths functions to see the impact on the code? How would I have to compile/link my code in order to try them out?
Thanks,
Oli
 100.0% | 82937 |       -- |     -- |Total
|  54.5% | 45213 |       -- |     -- |USER
||  15.2% | 12567 |  1252.56 |   9.1% |fast_waves_rk_fast_waves_runge_kutta_
||   4.9% |  4028 |   604.77 |  13.1% |src_turbdiff_turbdiff_
||   4.6% |  3800 |   364.13 |   8.8% |numeric_utilities_interpol_sl_tricubic_
||   4.1% |  3368 |   448.57 |  11.8% |src_slow_tendencies_rk_complete_tendencies_uvwtpp_
||   2.4% |  2008 |   445.34 |  18.2% |environment_putbuf_
||   2.1% |  1782 |   245.12 |  12.1% |src_advection_rk_advection_
||   2.1% |  1769 |   255.89 |  12.6% |src_runge_kutta_org_runge_kutta_
||   1.6% |  1362 |   357.93 |  20.8% |environment_getbuf_
||   1.6% |  1332 |   534.36 |  28.7% |src_gscp_hydci_pp_gr_
||   1.4% |  1138 |   146.15 |  11.4% |src_advection_rk_adv_upwind5_lat_
||   1.4% |  1131 |   138.14 |  10.9% |lmorg_initialize_loop
||   1.2% |  1004 |   192.37 |  16.1% |src_advection_rk_adv_upwind5_lon_
|  26.4% | 21870 |       -- |     -- |ETC
||   5.1% |  4213 |  1460.19 |  25.8% |__mth_i_dexp
||   4.2% |  3509 |  1248.63 |  26.3% |PtlEQPeek
||   2.8% |  2338 |   259.03 |  10.0% |__c_mzero8
||   2.1% |  1752 |   717.68 |  29.1% |fast_nal_poll
||   2.0% |  1665 |   374.32 |  18.4% |__mth_i_dpowd
||   1.6% |  1332 |   528.43 |  28.4% |PtlEQGet
||   1.5% |  1203 |   499.00 |  29.3% |__mth_i_dlog
||   1.2% |   977 |   343.05 |  26.0% |PtlEQGet_internal
||   1.1% |   899 |   432.91 |  32.5% |MPIDI_CRAY_smpdev_progress
|  19.1% | 15854 |       -- |     -- |MPI
||   9.1% |  7544 | 70473.83 |  90.4% |mpi_recv_
||   4.6% |  3823 |   227.10 |   5.6% |mpi_allgather_
||   1.9% |  1561 |    84.60 |   5.1% |mpi_scatter_
||   1.5% |  1213 |   156.15 |  11.4% |mpi_allreduce_
Hi Oli,
Which flags are you using? Given the symbol names, I’m assuming that you have “-Kieee” enabled. For the optimized versions ("__fmth_i_dexp" instead of “__mth_i_dexp”), please remove this flag. The “fast” version are slightly less precise (~1Ulp) but should improve performance.
For some other operations (sqrt, rsqrt, div), you can also try the flag “-Mfprelaxed”.
If you wish to try out your own versions of these routines, then you would need to rename these intrinsics to match your version name. A preprocessor directive such as “#define EXP MYEXP”, at the top of each of your source files should do the substitution for you.
Hope this helps,
Mat
Dear Mat,
Yes, this helps! The options I am using are…
-Kieee -Mbyteswapio -Mfree -Mpreprocess -Mcache_align -Mflushz -Mlre -Mprefetch -Mpreprocess -Mscalarsse -Mvect=noassoc -Mvect=sse -O3 -Mipa=fast,inline -fastsse
I will try out the suggestions you have made and post results as soon as I have them. Do you have any experience in using the ACML, as we are running on Quad-core AMD Opterons on a Cray XT4?
Cheers,
Oli
Hi Oli,
I’ve used it, but have not done much performance testing with it.
  • Mat
Mat,
I tried removing -Kieee and adding -Mfprelax to my compilation options and got the following results…
 100.0% | 78197 |       -- |     -- |Total
|  56.8% | 44386 |       -- |     -- |USER
||  16.0% | 12523 |  1293.95 |   9.4% |fast_waves_rk_fast_waves_runge_kutta_
||   4.8% |  3766 |   541.95 |  12.6% |src_turbdiff_turbdiff_
||   4.7% |  3700 |   384.86 |   9.4% |numeric_utilities_interpol_sl_tricubic_
||   4.3% |  3365 |   409.66 |  10.9% |src_slow_tendencies_rk_complete_tendencies_uvwtpp_
||   2.6% |  2050 |   459.89 |  18.3% |environment_putbuf_
||   2.3% |  1781 |   249.64 |  12.3% |src_runge_kutta_org_runge_kutta_
||   2.1% |  1650 |   230.54 |  12.3% |src_advection_rk_advection_
||   1.8% |  1388 |   358.70 |  20.6% |environment_getbuf_
||   1.6% |  1279 |   515.36 |  28.8% |src_gscp_hydci_pp_gr_
||   1.5% |  1134 |   137.31 |  10.8% |lmorg_initialize_loop
||   1.4% |  1084 |   108.88 |   9.1% |src_advection_rk_adv_upwind5_lat_
||   1.2% |   954 |   208.70 |  18.0% |src_advection_rk_adv_upwind5_lon_
||   1.0% |   767 |   250.12 |  24.6% |src_relaxation_sardass_
||   1.0% |   744 |   145.97 |  16.4% |src_slow_tendencies_rk_implicit_vert_diffusion_uvwt_
|  23.2% | 18152 |       -- |     -- |ETC
||   4.1% |  3213 |  1201.95 |  27.3% |PtlEQPeek
||   3.1% |  2386 |   295.83 |  11.0% |__c_mzero8
||   2.7% |  2083 |   806.15 |  27.9% |__fmth_i_dexp
||   2.2% |  1695 |   619.89 |  26.8% |fast_nal_poll
||   1.6% |  1232 |   483.04 |  28.2% |PtlEQGet
||   1.2% |   916 |   364.49 |  28.5% |__fmth_i_dlog
||   1.2% |   910 |   330.43 |  26.7% |PtlEQGet_internal
||   1.1% |   834 |   313.52 |  27.3% |MPIDI_CRAY_smpdev_progress
|  20.0% | 15659 |       -- |     -- |MPI
||   9.1% |  7147 | 66181.37 |  90.3% |mpi_recv_
||   5.1% |  4016 |   234.95 |   5.5% |mpi_allgather_
||   2.0% |  1567 |    79.37 |   4.8% |mpi_scatter_
||   1.7% |  1320 |   140.20 |   9.6% |mpi_allreduce_
Obviously we are using fast math routines now. The powd completely vanished below the cutoff (1%) and exp/log improved. So things seem to be working. Now I will have to investigate the impact on the results. People running meteorological codes are usually quite hesitant on using fast math libraries.
Concerning the ACML, I’m still trying to get it to run.
Thanks again,
Oli
