Faster R CNN Training stops after 1 Epoch
train.log (2.2 KB)
Everytime after only 1 epoch within my Faster RCNN training: I get this error:
I have attached my train.txt file
changed from inf to 0.606966927092, saving weights
File “/usr/local/bin/tlt-train-g1”, line 10, in
sys.exit(main())
File “./common/magnet_train.py”, line 30, in main
File “./faster_rcnn/scripts/train.py”, line 367, in main
IndexError: list index out of range
Hi ishan,
Could you please attach your full running log too? Thanks.
Attached is the entire running log toorunning.log (35.7 KB)
Hi ishan,
Is your below log missing?
<here, is it missing?>
I dont understand what you are alluding to by the ‘log file’. I have attached the full running log in the message before.
./faster_rcnn/scripts/train.py - this is the source code file
Could you please double check your dataset? Or could you run KITTI dataset successfully with default training spec inside the docker?
kitti_data_config {
images_dir: ‘/src/dataset/images’
labels_dir: ‘/src/dataset/labels’
Thanks, will check it out.
