I want to train a Faster-rcnn model with Transfer Learning Toolkit
I need it to detect a specific object from live video feed, and then extract the text that is in that object.
More specifically I need it to give me the licence-plate number.
My questions are:
Is it possible with faster-rcnn at all?
If yes:
How should i label my data? In each frame should i annotate the letters as well as the number
plate?
If you can give me code examples, that would be great, if not a general direction to research would be good too.
Thank you in advance!
I followed what they have done with the following things:
This is my train_kitti.txt
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tlt-experiments/tfrecords/kitti_trainval/*"
image_directory_path: "/workspace/tlt-experiments/data/training"
image_extension: "jpg"
target_class_mapping {
key: "a"
value: "a"
key: "b"
value: "b"
key: "c"
value: "c"
key: "d"
value: "d"
key: "e"
value: "e"
key: "f"
value: "f"
key: "g"
value: "g"
key: "h"
value: "h"
key: "j"
value: "j"
key: "k"
value: "k"
key: "l"
value: "l"
key: "m"
value: "m"
key: "n"
value: "n"
key: "p"
value: "p"
key: "r"
value: "r"
key: "s"
value: "s"
key: "t"
value: "t"
key: "u"
value: "u"
key: "v"
value: "v"
key: "w"
value: "w"
key: "x"
value: "x"
key: "y"
value: "y"
key: "z"
value: "z"
key: "zero"
value: "zero"
key: "one"
value: "one"
key: "two"
value: "two"
key: "three"
value: "three"
key: "four"
value: "four"
key: "five"
value: "five"
key: "six"
value: "six"
key: "seven"
value: "seven"
key: "eight"
value: "eight"
key: "nine"
value: "nine"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 325
output_image_height: 135
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "a"
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
key: "b"
value {
clustering_config {
key: "c"
value {
clustering_config {
key: "d"
value {
clustering_config {
key: "e"
value {
clustering_config {
key: "f"
value {
clustering_config {
key: "g"
value {
clustering_config {
key: "h"
value {
clustering_config {
key: "j"
value {
clustering_config {
key: "k"
value {
clustering_config {
key: "l"
value {
clustering_config {
key: "m"
value {
clustering_config {
key: "n"
value {
clustering_config {
key: "p"
value {
clustering_config {
key: "r"
value {
clustering_config {
key: "s"
value {
clustering_config {
key: "t"
value {
clustering_config {
key: "u"
value {
clustering_config {
key: "v"
value {
clustering_config {
key: "w"
value {
clustering_config {
key: "x"
value {
clustering_config {
key: "y"
value {
clustering_config {
key: "z"
value {
clustering_config {
key: "zero"
value {
clustering_config {
key: "one"
value {
clustering_config {
key: "two"
value {
clustering_config {
key: "three"
value {
clustering_config {
key: "four"
value {
clustering_config {
key: "five"
value {
clustering_config {
key: "six"
value {
clustering_config {
key: "seven"
value {
clustering_config {
key: "eight"
value {
clustering_config {
key: "nine"
value {
clustering_config {
model_config {
pretrained_model_file: "/workspace/tlt-experiments/pretrained_resnet18/tlt_resnet18_detectnet_v2_v1/resnet18.hdf5"
num_layers: 18
use_batch_norm: true
activation {
activation_type: "relu"
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "a"
value: 0.5
key: "b"
value: 0.5
key: "c"
value: 0.5
key: "d"
value: 0.5
key: "e"
value: 0.5
key: "f"
value: 0.5
key: "g"
value: 0.5
key: "h"
value: 0.5
key: "j"
value: 0.5
key: "k"
value: 0.5
key: "l"
value: 0.5
key: "m"
value: 0.5
key: "n"
value: 0.5
key: "p"
value: 0.5
key: "r"
value: 0.5
key: "s"
value: 0.5
key: "t"
value: 0.5
key: "u"
value: 0.5
key: "v"
value: 0.5
key: "w"
value: 0.5
key: "x"
value: 0.5
key: "y"
value: 0.5
key: "z"
value: 0.5
key: "zero"
value: 0.5
key: "one"
value: 0.5
key: "two"
value: 0.5
key: "three"
value: 0.5
key: "four"
value: 0.5
key: "five"
value: 0.5
key: "six"
value: 0.5
key: "seven"
value: 0.5
key: "eight"
value: 0.5
key: "nine"
value: 0.5
evaluation_box_config {
key: "a"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
key: "b"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "c"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "d"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "e"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "f"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "g"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "h"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "j"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "k"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "l"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "m"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "n"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "p"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "r"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "s"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "t"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "u"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "v"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "w"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "x"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "y"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "z"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "zero"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "one"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "two"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "three"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "four"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "five"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "six"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "seven"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "eight"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "nine"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 2.8
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 4.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.7
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.1
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.7
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.9
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.6
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 6.9
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 10.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.4
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 15.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.4
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 10.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.6
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.6
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.4
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 4.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.5
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 10.9
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 17.9
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 3.7
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.4
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 2.2
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 4.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 5.3
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 6.1
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 150
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "a"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
bbox_min_radius: 1.0
key: "b"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "c"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "d"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "e"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "f"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "g"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "h"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "j"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "k"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "l"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "m"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "n"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "p"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "r"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "s"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "t"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "u"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "v"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "w"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "x"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "y"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "z"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "zero"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "one"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "two"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "three"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "four"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "five"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "six"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "seven"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "eight"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
key: "nine"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
deadzone_radius: 0.400000154972
This is the number of instances of each character:
seven: 232
one: 396
four: 268
zero: 664
six: 455
two: 92
nine: 165
three: 56
eight: 188
five: 422
a: 355
c: 593
b: 233
e: 270
d: 323
g: 275
f: 340
h: 190
k: 335
j: 144
m: 95
l: 337
o: 1
n: 293
p: 192
s: 316
r: 66
u: 100
t: 294
w: 180
v: 387
y: 291
x: 445
z: 253
I adjusted the weights according to the data i have.
However, i still receive the same result as they did at the beginning.
I’m getting average precision at around 20%.
The highest accuracy is at 70% for one or two characters.
I tested with a different dataset I prepared before this one and the same thing happened. Am i training at the wrong resolution, do I not have enough data?
I would appreciate a bit of help!
I think it might be the fact that I want to train at 325x135.
Could you please tell me how I should train my model and label my pictures.
I’m getting live video feed at 1920x1080 detecting the licence plate with primary gie.
Then for the secondary gie i want it to detect the characters in the number plate.
Should i train on detecting characters on the full resolution?
I chose 325x135 as that was the average size of the number plate in the frame.
Morganh
February 10, 2020, 3:30am
5
Hi nooffence7100,
For detectnet_v2 network, see Integrating TAO Models into DeepStream — TAO Toolkit 3.22.05 documentation
DetectNet_v2
•Input size: C * W * H (where C = 1 or 3, W > =480, H >=272 and W, H are multiples of 16)
•Image format: JPG, JPEG, PNG
•Label format: KITTI detection
Please set the input image’s size to “W > =480, H >=272 and W, H are multiples of 16”.
What’s your size of your input image?
For example, if your input image is 1920x1080, then you can resize them to 960x544 with PIL or cv2.
Also please resize the corresponding labels.
Calculate the ratios of each class quantity, and set different class_weight in the training spec.
Morganh
February 10, 2020, 3:31am
6
Plese note that above-mentioned is for detectnet_v2 network, not faster-rcnn network.
Morganh:
Hi nooffence7100,
For detectnet_v2 network, see https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#requirements
DetectNet_v2
So you are telling me that if I have input image of 1920x1080,
I detect the licence plate with primary-gie trained on 1920x1080,
Then I can use a trained on 1920x1080 char detector, that will work on the Region Of Interest from the primary-gie only.
Does that mean it crops the region of interest and works on it, or just finds characters in that box.
That is confusing me, I understand it’s probably a stupid question.
Thanks in advance.
Morganh
February 10, 2020, 2:15pm
8
Hi nooffence7100 ,
Actually there are two kinds of work for your project.
One is LPD, licence plate detection.
The other is LPR, licence plate recognition.
For LPD, if you feed the licence plate images/labels to TLT detectnet_v2 network, then the output model will detect licence plate only from the inference images. The model cannot detect what characters of licence plate are.
For LPR, if you feed the characters images/labels to TLT detectnet_v2 network, just like https://devtalk.nvidia.com/default/topic/1069397/transfer-learning-toolkit/detectnet-v2-18-layers-for-character-recognition-35-classes-/post/5419070/#5419070 , the model will recognise characters
