I am trying to convert a Tensorflow detection graph from a pre-trained faster rcnn model to a TensorRT inference graph with Tensorflow 1.15.5.
I use the code from GitHub - NVIDIA-AI-IOT/tf_trt_models: TensorFlow models accelerated with NVIDIA TensorRT.
The TensorRT inference graph is used for inference on a Nvidia Jetson Nano.
When I execute following command:
frozen_graph, input_names, output_names = build_detection_graph(
config=config_path,
checkpoint=checkpoint_path,
score_threshold=0.3,
iou_threshold=0.5,
batch_size=1)
I get the following error, which occurs with every rcnn model from the repo.
AttributeError Traceback (most recent call last)
<ipython-input-58-be040ed41095> in <module>()
4 score_threshold=0.3,
5 iou_threshold=0.5,
----> 6 batch_size=1
7 )
<ipython-input-25-686a48394be8> in build_detection_graph(config, checkpoint, batch_size, score_threshold, iou_threshold, force_nms_cpu, replace_relu6, remove_assert, input_shape, output_dir)
104 elif config.model.HasField('faster_rcnn'):
105 if score_threshold is not None:
--> 106 config.model.faster_rcnn.second_stage_post_processing.score_threshold = score_threshold
107 if input_shape is not None:
108 config.model.faster_rcnn.image_resizer.fixed_shape_resizer.height = input_shape[0]
AttributeError: 'PostProcessing' object has no attribute 'score_threshold'
Code of build_detection_graph is:
def build_detection_graph(config, checkpoint,
batch_size=1,
score_threshold=None,
iou_threshold=None,
force_nms_cpu=True,
replace_relu6=True,
remove_assert=True,
input_shape=None,
output_dir='.generated_model'):
"""Builds a frozen graph for a pre-trained object detection model"""
config_path = config
checkpoint_path = checkpoint
# parse config from file
config = pipeline_pb2.TrainEvalPipelineConfig()
with open(config_path, 'r') as f:
text_format.Merge(f.read(), config, allow_unknown_extension=True)
config.model.faster_rcnn.image_resizer.fixed_shape_resizer.width = input_shape[1]
