fastest way to access the 8 MSB of an (unsigned) int?
what is the fastest way to access the 8 MSB of an (unsigned) int on the device?
Right now I’m doing it by shifting right 24bits.
Code sniplet:
unsigned int a,b;
a = 0x12345678;
b = a >> 24;
a &= 0xFFFFFF;
/* in this example a is 0x345678 and b is 0x12 now */
So I’m wondering if there is a faster way, e.g. cast “a” to a packed uchar and read the specific byte.
Regards,
Oliver
The shift is already a single clock instruction… no need to optimize it further.
unsigned int a;
unsigned char bytes[4];
*(unsigned int *)bytes = a;
Now bytes[3] - most significant 8 bits, byte[2] is the next 8 and so on… (Assuming little endian)
Simble, no?
