fatal compiler error
I get the error message below trying to compile a fortran file on a x86-64 Linux system… Unfortunately, the error message is not very descriptive of the problem and I can’t make much sense of it other than that the compiler gets terminated by signal 11. The file compiles on IRIX, HP-UX, IA64, x86, so I believe it’s fine as far as syntax etc goes. Any help would be greatly appreciated.
Thanks,
Stefan
[voelker@goliath amd64]$ pgf90 -c -ospltblck.o spltblck.f
pgf90-Fatal-/software/comp_pgi_5.1/linux86-64/5.1/bin/pgf901 TERMINATED by signal 11
Arguments to /software/comp_pgi_5.1/linux86-64/5.1/bin/pgf901
/software/comp_pgi_5.1/linux86-64/5.1/bin/pgf901 spltblck.f -opt 1 -terse 1 -inform warn -nohpf -nostatic -x 15 2 -x 49 0x400004 -x 51 0x20 -x 57 0x4c -x 58 0x10000 -x 124 0x1000 -x 57 0x10000 -x 58 0x31040 -x 48 4608 -x 49 0x100 -x 120 0x200 -stdinc /software/comp_pgi_5.1/linux86-64/5.1/include:/usr/local/include:/usr/lib/gcc-lib/x86_64-redhat-linux/3.2.3/include:/usr/lib/gcc-lib/x86_64-redhat-linux/3.2.3/include:/usr/include -def unix -def __unix -def unix -def linux -def __linux -def linux -def inline= -def NO_INLINE -def __NO_MATH_INLINES -def x86_64 -def LONG_MAX=9223372036854775807L -def ‘SIZE_TYPE=unsigned long int’ -def ‘PTRDIFF_TYPE=long int’ -def __THROW= -vect 48 -output /tmp/pgf90aaaaaufwab.ilm
Hi Stefen,
Can you send a brief description of the problem and this file to tpr@pgroup.com? It’s very bad when the compiler gets a segmentation fault so we would like to get it fixed as soon as possible.
Thanks,
Mat
Hi Mat,
I can send you the file, but you will have sign an NDA before I can do so. I’ll start the paperwork on our end. Shouldn’t take more than a day or two. Is there a fax number I can send the NDA to once it’s complete?
Thanks,
Stefan
P.S. Feel free to contact me at my email address (which I assume you have access to) if you don’t want to publish the fax # or other contact info in this forum.
Our contact Information is:
The Portland Group
STMicroelectronics
9150 SW Pioneer Ct, Suite H
Wilsonville, OR 97070
Phone: 503-682-2806
Fax: 503-682-2637
Since we’re now part of a larger company, we have to pass NDAs to ST’s legal department. This can take some time. You can send it to my attention and I’ll pass it on the appropriate person.
Thanks,
Mat
Mat -
In order to have the NDA written up, I need the name and title of the person who will be signing it on behalf of The Portland Group.
Thanks,
Stefan
FYI to anyone reading this post. I contacted svoelker directly and determined that upgrading to release 5.2 solved his problem.
