fatal error C1189: #error : Building MFC application with /MD[d] (CRT dll version) requires MFC sha
hi, all.
Recently i build a MFC project. It works fine.
After I add a cu file to this project. Appears the error:
[codebox]fatal error C1189: #error : Building MFC application with /MD[d] (CRT dll version) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d][/codebox]
I have set the values following( Debug/Win32 ):
Configuration Properties > General :
 Use of MFC : Use MFC in a Shared DLL
Configuration Properties > C/C++ > Code Generation :
 Runtime Library : /MDd
Configuration Properties > CUDA Build Rule v2.3.0 > Hybrid CUDA/C++ :
I don’t know what is the error mean, please help me.
So strange.
When I delete the line: #include “stdafx.h” in the cu files, it can be compiled.
But this project was coded a few weeks ago and the compiler required the header file.
AFAIK CUDA stuff (like cudart.dll) was built with /MT (/MTd for debug versions). There’s a runtime library mismatch.
