Fatal error: gstnvdsmeta.h: No such file or directory
im running through docker container IMAGE nvcr.io/nvidia/deepstream 5.1-21.02-base, and i get the below error . kindly assist with the linking library
# NVDS_VERSION:=1.0
NVDS_VERSION:=5.1
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.cpp=.o)
CFLAGS+= -I../../../includes \
        -I /usr/local/cuda-$(CUDA_VER)/include
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS:= $(shell pkg-config --libs $(PKGS))
LIBS+= -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
       -lm -lcuda -lgstrtspserver-1.0 -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lm \
       -Wl,-rpath,$(LIB_INSTALL_DIR)
g++ -c -o PoC_Bottle.o -I../../../includes -I /usr/local/cuda-11.2/include -pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include PoC_Bottle.cpp
 fatal error: gstnvdsmeta.h: No such file or directory
 #include "gstnvdsmeta.h"
compilation terminated.
i have created a folder called “src” and kept the c++ files
path : /opt/nvidia/deepstream/deepstream-5.1/src
Hi @h9945394143 ,
This looks like a Deepstream issue, recommend you to raise it to respective forum
Any help from the Nvidia team ???
This file should located at /opt/nvidia/deepstream/deepstream-5.1/sources/includes/ folder. Did you checked it?
its not there , is there an command to fill in .!!
Unfortunately, I could not find. You may include all source files in your folder. The base container has only plugins and libraries.
i need few headers files such as gstnvdsmeta.h: … ?? is there any command or i call PULL from base container ?
My deepstream command
xhost +
docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY nvcr.io/nvidia/deepstream:5.1-21.02-base
I tried to download deepstream source file, extract it into /tmp and copy the sources/includes folder into the deepstream folder
apt update
apt install wget
cd /tmp
mkdir deepstream_temp && cd deepstream_temp
wget -O deepstream_sdk_v5.1.0_x86_64.tbz2 https://developer.download.nvidia.com/assets/Deepstream/DeepStream_5.1/deepstream_sdk_v5.1.0_x86_64.tbz2
tar -jxvf deepstream_sdk_v5.1.0_x86_64.tbz2
cd /opt/nvidia/deepstream/deepstream-5.1
mkdir sources
cp -r /tmp/deepstream_temp/opt/nvidia/deepstream/deepstream-5.1/sources/includes sources/
Hope it works on your setup too
Best regards
