Faux NVFP2 Qwen3.8-Flash-Next Single Spark
With the amount of work done for my prior the PLE/ HASHK method I now present a Faux NVFP2 Qwen3.8-Flash-Next on a Single GB10/ DGX Spark .
Give credit where credit is due to please.
Managed to push the model for throughput
Workload :
code / edit / prose / math tok/s
70.0 / 77.6 / 53.4 / 77.3
With this line The routed experts are stored at 2 bits per weight and read by a dedicated Triton kernel makes me NOT wanting to try this for a bit more speed.
That’s cool no gun to your head telling your to try it .
Cool work, what’s the main advantage here, just taking up less space / maybe faster speeds?
Maybe faster speeds is vague. Is it faster than the public builds in the benchmarks yes. Can use the benchmark as reference and compare it to whatever pipelines you’re using now.
Honestly i dont think 80 on prose is possible but will try a few more things as current methods are near 90% of the bandwidth limits. 70 is pretty damn good though for those with single GB10/Spark
Pretty much double prose TOK/s with minimum losses since release not bad.
