Hi everyone;
When I bring an FBX character to the omniverse create screen, it lost expressions. How can I solve this issue?
I’d like to explain the process that I did first to you.
I created a character CC4 and animated it in iClone8. After I exported these character with MotionPlus( Motion+visime+expression) as an FBX file for C4D and 3dS Max. Animation works on these platforms perfectly. When I call the characters into the Omniverse screen for rendering, Expressions don’t come. Only motions and visimes come, no eye-lip or eyebrow motions.
To try,
I exported the character as a USD file from iclone8 then it works perfectly in the omniverse with MotionPlus
I exported the character as an FBX file from iclone8 then it works perfectly in C4D and 3DS_Max with MotionPlus,
Then I used the same FBX file with animation on the omniverse but the expressions don’t work in the Omniverse Create.
How can I use these FBX files with emotions on the Omniverse screen?
Please could you share info about if you have, how can I call expressions to the omniverse screen or tide up the character? Thanks a lot
