FBX Installation
I’m having trouble capturing videos. I’m trying to run the official code, however im getting an error saying that i need to have fbx python bindings on my machine. When I try to install it through the official link that is also linked in the error itself, im having trouble Help finding a .whl file at installation process. Can someone help me with this please, I’m running to this issue for very long time and couldn’t find a solution.
import gym
import isaacgym
import isaacgymenvs
import torch
num_envs = 64
envs = isaacgymenvs.make(
seed=0,
task=“Ant”,
num_envs=num_envs,
sim_device=“cuda:0”,
rl_device=“cuda:0”,
graphics_device_id=0,
headless=False,
multi_gpu=False,
virtual_screen_capture=True,
force_render=False,
envs.is_vector_env = True
envs = gym.wrappers.RecordVideo(
envs,
“./videos”,
step_trigger=lambda step: step % 10000 == 0, # record the videos every 10000 steps
video_length=100 # for each video record up to 100 steps
envs.reset()
print(“the image of Isaac Gym viewer is an array of shape”, envs.render(mode=“rgb_array”).shape)
for _ in range(100):
actions = 2.0 * torch.rand((num_envs,) + envs.action_space.shape, device = ‘cuda:0’) - 1.0
envs.step(actions)
Did you find a solution for this ? and if so where did you find the fbx file on the site ?
I did not. I have tried everything but fbx still not works.
