hi,
Recentlly,we build a system:a FCB-EV7500 Camera connect to TX2 with MIPI interface it is used to input data.I wonder how can I get the image data in my program.
I used to get data in the Jetson board with the following code:
#include <opencv2/opencv.hpp>
std::string get_tegra_pipeline(int width, int height, int fps) {
return "nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)" + std::to_string(width) + ", height=(int)" +
std::to_string(height) + ", format=(string)I420, framerate=(fraction)" + std::to_string(fps) +
"/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink";
int main() {
// Options
int WIDTH = 1920;
int HEIGHT = 1080;
int FPS = 30;
// Define the gstream pipeline
std::string pipeline = get_tegra_pipeline(WIDTH, HEIGHT, FPS);
std::cout << "Using pipeline: \n\t" << pipeline << "\n";
// Create OpenCV capture object, ensure it works.
cv::VideoCapture cap(pipeline, cv::CAP_GSTREAMER);
if (!cap.isOpened()) {
std::cout << "Connection failed";
return -1;
// View video
cv::Mat frame;
while (1) {
cap >> frame; // Get a new frame from camera
// Display frame
imshow("Display window", frame);
cv::waitKey(1); //needed to show frame
Will this still work in my own board and camera.
You have make sure your sensor driver working will first. Try the gst-launch-1.0 pipeline first.
hi,
I’d like to check my camera with
v4l2-ctl --all -d /dev/video0
but it tells me “]v4l2-ctl :command not found”.
Besides,should I add the camera driver by myself,if that are there any reference?
You need install it by v4l-utils by sudo apt-get install v4l-utils.
Please find the sensor programing guide in the l4t document from download center.
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-2-ga
Hi,ShaneCCC
Maybe I need not configure or add the camera driver.
The camera is connect to FPGA directly and FPGA output the image data by MIPI interface, what should I do is find a way to get data from the MIPI interface.
You exactly need to implement a driver for your FPGA.
I can not understand what do you mean.
FPGA can get data from the camera and it changed to mipi interface output.
I do not konw how to get the data from the mipi interface.Does opencv can work?
You can’t do anything before to implement a MIPI driver to tell tegra what’s the FPGA configure.
A driver for FPGA?
How can I add the driver and validate whether it works or not?
Are there any samples?
Maybe like this
imx185_a@1a {
compatible = "nvidia,imx185";
reg = <0x1a>;
devnode = "video0";
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="imx185";
post_crop_frame_drop = "0";
use_decibel_gain = "true";
delayed_gain = "true";
use_sensor_mode_id = "true";
mode0 {
mclk_khz = "37125";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
min_gain_val = "0"; /* dB */
max_gain_val = "48"; /* dB */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1.5";
max_framerate = "30";
min_exp_time = "30";
max_exp_time = "660000";
embedded_metadata_height = "1";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
liimx185_imx185_out0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&liimx185_csi_in0>;
It’s for camera or for FPGA?
