FDTD speed problem
I am trying to use CUDA to solve FDTD question. I have speed up problem.
The red section I highlight is where take the longest calculation time.
I use the texture memory for those read-only variable. I use global memory For those variable
that need update.
[codebox]
global void EField_Texture( float* Ex, float* Ey, float* Ez, float* V ,float* Hx, float* Hy, float* Hz, float* V1, float* V2,int xe1,int xs2,int zs,int ze,float dz,int xe2,int xs3,int n,int yss1,int yss2)
int tx = blockIdx.x * blockDim.x + threadIdx.x;
for (int i=1; i<16; i++)
		if (tx-i*(81*76)>81-1 && tx-i*(81*76)<81*75)
		if((tx+1) % 81 !=0 )
           int test1;
           test1=(tex1Dfetch( rT1, tx )* Ex[tx]+tex1Dfetch( rT2, tx )*(Hz[tx]-Hz[tx-81])-tex1Dfetch( rT4, tx )*(Hy[tx]-Hy[tx-81*76]))*1000000;
           Ex[tx]=(float) test1/1000000;
   if (tx-i*(81*76)>=0 && tx-i*(81*76)<81*75)
         if((tx+1) % 81 !=0 && (tx) % 81 !=0  )
           int test1;
           test1=(tex1Dfetch( rT6, tx )*Ey[tx]+tex1Dfetch( rT7, tx )*(Hx[tx]-Hx[tx-81*76])-tex1Dfetch( rT9, tx )*(Hz[tx]-Hz[tx-1]))*1000000;
           Ey[tx]=(float) test1/1000000;
for (int i=0; i<16; i++)
		   int test1;
           test1=(tex1Dfetch( rT10, tx )* Ez[tx]+tex1Dfetch( rT11, tx )*(Hy[tx]-Hy[tx-1])-tex1Dfetch( rT12, tx )*(Hx[tx]-Hx[tx-81])-tex1Dfetch( rT13, tx )*V[n-1])*1000000;
           Ez[tx]=(float) test1/1000000;
// Voltage sampling
float sum1=0;
float sum2=0;
int round=((xe1+xs2)/2)+0.5;
for (int z=zs-1 ; z<ze-1; z++)
	sum1 =sum1+ Ez[round-1+(yss1-1)*81+z*81*76];
V1[n-1] = -dz*sum1;
round=((xe2+xs3)/2)+0.5;
	sum2 = sum2+Ez[round-1+(yss2-1)*81+z*81*76];
V2[n-1] = -dz*sum2;
[/codebox]
That is the first subroutine for my Electrical field. Then follow with another two subroutines to update the data.
Run a 3000 times loop. I ran it with a 8400 card. I had the calculation time is 10 times longer than CPU.
[codebox]
for(int n=0;n<3000;n++)
   printf("\nloop%d",n);
   time = time+dt/2;
   int nn = nwrap[n-1];
   int ln=nwrap[n+2-1];
  EField_Texture<<< ceil( (float)size / BLOCK_DIM ), BLOCK_DIM >>>( dev_Ex,dev_Ey,dev_Ez,dev_V,dev_Hx,dev_Hy,dev_Hz,dev_V1,dev_V
2,xe1,xs2,zs,ze,dz,xe2,xs3,n,yss1,yss2);
   tv[n-1] = time*1e+9;  // Voltage time array in nano seconds
 ABC_Texture<<< ceil( (float)size / BLOCK_DIM ), BLOCK_DIM >>>( dev_Ey,dev_Ez,dev_ezlx1,dev_ezlx2,dev_eylx1,dev_eylx2,nn,ln,
dev_Ex,dev_ezly1,dev_ezly2,dev_exly1,dev_exly2,dev_exlz1,dev_
exlz2,dev_eylz1,dev_eylz2,dev_nwrap,n);
HField_Texture<<< ceil( (float)size / BLOCK_DIM ), BLOCK_DIM >>>( dev_Hx,dev_Hy,dev_Hz,dev_Ex,dev_Ey,dev_Ez,dev_I1,dev_I2,xe1,
xs2,yss1,ze,xe2,xs3,yss2,dz,n,dx);
   time = time+dt/2;
   ti[n-1] = time*1e+9;  // Current time array in nano seconds
[/codebox]
I also tried to put the EField_Texture, ABC_Texture, and HField_Texture into the same kernel instead of calling 3 subroutines.
Then I had another problem which is the program seems start running the next calculation before finished the current one.
I can send a code to you if you need to see the code to help me.
Thank you very much
Eric
