Feature Request - Automate Character Creator Characters
I know not everyone that uses A2F uses Character Creator, but if you move the Preset select to before you click Setup Character much of the selections could be automated.
(What does Numbers Visibility Mean?)
If you have a person select CC4 option first, and select the character that was brought in, you could iterate through the meshes and select all these options for the user.
I know it doesn’t take that long to select about 5 meshes and click the + sign for each one, but this would make the whole process seem much simpler.
Then why you are at it, you could automate the Begin Post Wrap, Jaw Motion Prop, Tongue Motion prep and Tongue Post Wrap. I would much prefer to watch a progress bar do the processing. It is especially hard for me, because I have to use Windows Magnifier to read the list of meshes under character root because the font is too small for me.
The less buttons a user has to click, the easier it seems and the more people will use Audio2Face. I often (most of the time) get to the end and my character’s mouth doesn’t move. I do better if I don’t click the Get Started option on the first tab, and go straight to Character Transfer.
Please consider this, and other Character Creator users please comment if you also think this would be helpful.
Thanks for your suggestions @DataJuggler
I’ll bring this to our team’s attention.
By the way, Number Visibility turns On and Off the numbers of the corresponding points. It’s useful when working on non-standard characters to find the matching points of the 2 faces easier.
It seems Reallusion team is working on these feature requests already and will make it available as an extension when it’s ready.
Thanks for the update. I finally have Audio2Face figured out, or at least thte basics. Not sure about the emotions yet.
