FEC display N/A on adapter
We used OSFP SR4 on the CX7 adapter to connect to the QM9790 switch, but the FEC showed differently.
  • N/A is displayed On adapter
  • Standard_RS-FEC - (544,514) displayed on switch port
    I have tried to upgrade the latest firmware or replace the optical module,still the same .
    Then I installed another HCA and found that FEC displayed normally and his firmware was factory default.(FW version 28.38.1900 ) But when I upgraded it (FW version 28.43.1014 ), the FEC showed N/A
################ adapter
Operational Info
State : Active
Physical state : Disabled
Speed : IB-NDR
Width : 4x
FEC : N/A
Loopback Mode : No Loopback
Auto Negotiation : ON
Supported Info
Enabled Link Speed : 0x00000080 (NDR)
Supported Cable Speed : 0x00000080 (NDR)
Troubleshooting Info
Status Opcode : 0
Group Opcode : N/A
Recommendation : No issue was observed
Tool Information
Firmware Version : 28.43.1014
amBER Version : 3.3
MFT Version : mft 4.29.0-131
##############switch
Operational Info
State : Active
Speed : IB-NDR
Width : 4x
FEC : Standard_RS-FEC - (544,514)
Supported Info
Status Opcode : 0
Group Opcode : N/A
Tool Information
Firmware Version : 31.2012.4036
amBER Version : 3.3
The same adapter and switch in our factory on different server shows normal like this
Operational Info
State : Active
Speed : IB-NDR
Width : 4x
FEC : Ethernet_Consortium_LL_50G_RS_FEC_PLR -(272,257+1)
Hi
Let’s try turn off “Auto Negotiation” by command
mlxlink -d </dev/> --link_mode_force --speeds HDR
Once the speed is set, you must toggle the link so the above changes will take place:
mlxlink -d -a TG
Thanks for reply
When I used it recently, the problem disappeared
I will do some experiments according to your commands
