1- disabled nouveau
2- installed without problems driver 343.36 or 346.22
3- reboot
4- after login, desktop does not work…just a gray screen with the mouse running, I need run ctrl+alt+F2 and uninstall nvidia and using nouveau back
screenshot bug http://pt-br.tinypic.com/view.php?pic=2u78wnn&s=8#.VJMOslAIAs
my card is GTS 450
kernel 3.17.7-300.fc21.x86_64
nvidia-bug-report.log.gz (88.3 KB)
Are you using the rpmfusion nvidia packages?
rpmfusion works fine here
$ inxi -GS
System: Host: localhost.localdomain Kernel: 3.18.1-2.fc21.1.x86_64 x86_64 (64 bit)
Desktop: Cinnamon 2.4.5 Distro: Fedora release 21 (Twenty One)
Graphics: Card: NVIDIA GF106 [GeForce GTS 450]
Display Server: Fedora X.org 116.29.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
Resolution: 1920x1080@60.00hz
GLX Renderer: GeForce GTS 450/PCIe/SSE2
GLX Version: 4.4.0 NVIDIA 343.36
Without any debug no one is able to help you (see link)
https://devtalk.nvidia.com/default/topic/522835/linux/if-you-have-a-problem-please-read-this-first/
hummmm you are using Cinnamon, here using gnome 3 default fedora 21
Cinnamon is the only desktop for me.
https://admin.fedoraproject.org/pkgdb/packager/leigh123linux/
I wonder if your issue is GDM related.
gdm work…the problem occurs after you log in gdm
testing here…
fedora 21 + cinnamon = nvidia driver 343.36 or 346.22 work !! (gdm show up for login and cinnamon is loaded later)
fedora 21 + gnome 3.14 ( fedora default) = nvidia driver 343.36 or 346.22 bug (gdm show up for login but gnome is not loaded later)
I’m surprised gnome-shell is failing (as cinnamon works), your not trying any thing fancy like wayland?
Fedora 21 will come with GNOME 3.14, which already runs reasonably well on Wayland. Want to find out? It’s super easy to try it out! Let’s take a look at how to run GNOME on Wayland in Fedora 21, what already works, and what is yet to be finished. To...
gnome default (without wayland)
