Fedora 25, 375.66 installed, OpenGL not supported?
Running Fedora 25 and using the 3D controller GM107GLM [Quadro M2000M] (rev a2), after “some waiting” since the release of kernel 4.10, I installed 375.66. “dkms status” shows it’s installed, lsmod shows the driver is loaded:
lsmod | grep nvidia
nvidia_drm 45056 0
nvidia_modeset 790528 1 nvidia_drm
nvidia 12304384 1 nvidia_modeset
drm_kms_helper 155648 2 i915,nvidia_drm
drm 352256 5 i915,nvidia_drm,drm_kms_helper
but when I try start any program that needs OpenGL (which used to work before, no libraries removed…) I get the message that “this system doesn’t support OpenGL”. Searching and asking forums gave no solutuon. Any clue what’s going on?
Yeah, install NVIDIA drivers via RPM Fusion.
Also, without nvidia-bug-report no one will be able to help you.
That was my first attempt to use the M2000M controller. After trying I went for the proprietary driver. However, follwing your suggestion, I find:
sudo dnf install akmod
akmod-ndiswrapper-1.60-2.fc25.x86_64
akmod-nvidia-1:375.39-2.fc25.x86_64
So rpm fusion isn’t updated yet to .66, i.e. still on the 4.8 kernel?
Rpmfusion has .66 and the previous .39 driver was patched to work 4.9 and 4.10 kernel
http://download1.rpmfusion.org/nonfree/fedora/updates/25/x86_64/repoview/xorg-x11-drv-nvidia.html
Does this also apply for the Optimus? Because that’s what
01:00.0 3D controller: NVIDIA Corporation GM107GLM [Quadro M2000M] (rev a2)
is. It’s not my primary graphics card.
nvidia-bug-report.log.gz (137 KB)
