Log file: UNTITLED - Pastebin Service
I wasn’t able to pin down the exact cause. I’m using a distributrion from RPMFusion.
It looks like disabling the nouveau module didn’t work. It’s still loaded and binding to your GPU before the nvidia driver is able to.
Loading the nouveau driver is only due to fedora’s fallback mechanism when the nvidia driver doesn’t load. In this case due to being unsigned.
Please disable secure boot in bios.
Thank you! I followed RPMFusion’s guide on Secure Boot and can confim it works now. Howto/Secure Boot - RPM Fusion
