Fedora 38 (KDE) Black Screen On Boot. Will boot to desktop approx 1 in 15 times. Possible race condition?
Fedora 38 (KDE Plasma)
RTX 3070 Ti
Drivers installed via RPMFusion
As per the subject. Since installing Fedora 38 (KDE) it has become increasingly difficult to boot to a desktop environment as the majority of the time I will just get a black screen instead of the login prompt. If you see the output from /var/log/messages below you can see that a number of checks fail during boot resulting in an attempt to fallback to nouveau.
I suspect this must be some sort of race condition because multiple restart attempts will eventually boot successfully and everything works perfectly. Not sure if it is coincidence but I have discovered that if I enable the grub menu to always show, wait 3 seconds and then select the first boot option I can often manage to get to the desktop environment in maybe 1 in 5 times.
The following is shown when the following command is run:
sudo cat /var/log/messages | grep nvidia
Aug 13 11:59:49 fedora systemd[1]: Starting nvidia-powerd.service - nvidia-powerd service…
Aug 13 11:59:49 fedora /usr/bin/nvidia-powerd[1041]: nvidia-powerd version:1.0(build 1)
Aug 13 11:59:49 fedora kernel: nvidia: loading out-of-tree module taints kernel.
Aug 13 11:59:49 fedora kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Aug 13 11:59:49 fedora kernel: nvidia: module verification failed: signature and/or required key missing - tai
nting kernel
Aug 13 11:59:49 fedora kernel: nvidia: module license taints kernel.
Aug 13 11:59:49 fedora kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Aug 13 11:59:49 fedora kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=non
e:owns=none
Aug 13 11:59:50 fedora (udev-worker)[740]: nvidia: Process ‘/usr/bin/bash -c ‘/usr/bin/mknod -Z -m 666 /dev/nv
idiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255’’ failed with exit code 1.
Aug 13 11:59:50 fedora (udev-worker)[780]: nvidia: Process ‘/usr/bin/bash -c ‘for i in $(cat /proc/driver/nvid
ia/gpus/*/information | grep Minor | cut -d \ -f 4); do /usr/bin/mknod -Z -m 666 /dev/nvidia${i} c $(grep nvi
dia-frontend /proc/devices | cut -d \ -f 1) ${i}; done’’ failed with exit code 1.
Aug 13 11:59:50 fedora kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietar
y module nvidia, inheriting taint.
Aug 13 11:59:50 fedora kernel: nvidia-uvm: Loaded the UVM driver, major device number 509.
Aug 13 11:59:50 fedora kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 5
35.86.05 Fri Jul 14 20:20:58 UTC 2023
Aug 13 11:59:50 fedora kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Aug 13 11:59:51 fedora /usr/bin/nvidia-powerd[1041]: No matching GPU found
Aug 13 11:59:51 fedora /usr/bin/nvidia-powerd[1041]: Failed to initialize RM Client
Aug 13 11:59:51 fedora systemd[1]: nvidia-powerd.service: Main process exited, code=exited, status=1/FAILURE
Aug 13 11:59:51 fedora systemd[1]: nvidia-powerd.service: Failed with result ‘exit-code’.
Aug 13 11:59:51 fedora systemd[1]: Failed to start nvidia-powerd.service - nvidia-powerd service.
Aug 13 11:59:51 fedora systemd[1]: nvidia-powerd.service: Consumed 1.114s CPU time.
Aug 13 11:59:51 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system
_r:init_t:s0 msg=‘unit=nvidia-powerd comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=
? res=failed’
Aug 13 11:59:51 fedora kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
Aug 13 11:59:51 fedora systemd[1]: nvidia-fallback.service - Fallback to nouveau as nvidia did not load was sk
ipped because of an unmet condition check (ConditionPathExists=!/sys/module/nvidia).
As you can see, a number of Process calls fail with exit code 1 during boot. I have never had any issues with Fedora 37 (KDE).
Bug report attached
nvidia-bug-report.log.gz (491.9 KB)
[ 0.000000] Command line: BOOT_IMAGE=(hd3,gpt2)/root/boot/vmlinuz-6.4.7-200.fc38.x86_64 root=UUID=3e91a349-7ee7-4277-a6ae-76a1c6ea352c ro rootflags=subvol=root rd.driver.blacklist=nouveau modprobe.blacklist=nouveau resume=UUID=db5da49c-ae92-43a0-9555-bb6dbcfec4d2 rhgb quiet
You are missing modeset parameters for nvidia drivers.
Probably adding it will do the trick
