Fedora fails to work with 525 driver branch
I run Fedora 37. While the drivers compile, I have not been successfully able to run the 525 range of drivers - not 525.60, 525.78 or 525.85. The system will boot, but X will fail to start.
I am able to run successfully using 520.56.06.
My card is a GTX1060 3GB. Is 525-* compatible with my card?
On a side note, since 520 (possibly earlier) I am seeing a number of errors when the driver compiles and when I’m running. Everthing is working, but I see messages similar to this when running 520:
Jan 23 00:37:29 fedora kernel: nvidia 0000:01:00.0: device [10de:1c02] error status/mask=00001000/0000a000
Jan 23 00:37:29 fedora kernel: nvidia 0000:01:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
There are thousands of them in my system log. I don’t know if these are relevant or are safe to ignore.
