Hello Friends:
The two most recent Fedora kernels – installed during dnf -y updates – no longer allow the X server to start. I get a GLX error.
I’ve seen various posts regarding compilation failures against the Fedora 4.10.x kernel series, but those posts involved the NVIDIA driver from nvidia.com; not from the Negativo17 repository, which I use.
Below is my setup, followed by the GLX error I am getting when I try to start X the server.
Any ideas how to fix (possibly patch) this?
See below and thank you in advance! =:)
The FEDORA kernels installed …
4.10.17-200.fc25.x86_64 -- FAILS
4.10.15-200.fc25.x86_64 -- FAILS
4.10.14-200.fc25.x86_64 -- WORKS <--- I'm booted off of this one, where X starts up successfully.
The NVIDIA RPMs installed (from the Negativo17 repository) …
akmod-nvidia-381.22-2.fc25.x86_64
kmod-nvidia-4.10.14-200.fc25.x86_64-381.22-2.fc25.x86_64
kmod-nvidia-4.10.15-200.fc25.x86_64-381.22-2.fc25.x86_64
kmod-nvidia-4.10.17-200.fc25.x86_64-381.22-2.fc25.x86_64
nvidia-driver-381.22-6.fc25.x86_64
nvidia-driver-cuda-libs-381.22-6.fc25.x86_64
nvidia-driver-libs-381.22-6.fc25.x86_64
nvidia-libXNVCtrl-381.22-1.fc25.x86_64
nvidia-settings-381.22-1.fc25.x86_64
The exception …
X.Org X Server 1.19.3
Release Date: 2017-03-15
X Protocol Version 11, Revision 0
Build Operating System: 4.9.3-200.fc25.x86_64
Current Operating System: Linux y700 4.10.17-200.fc25.x86_64 #1 SMP Mon May 22 18:12:57 UTC 2017 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.10.17-200.fc25.x86_64 root=/dev/sda2 ro gfxpayload=vga=normal quiet rd.driver.blacklist=nouveau net.ifnames=0 biosdevname=0 LANG=en_US.UTF-8
Build Date: 15 March 2017 06:37:12PM
Build ID: xorg-x11-server 1.19.3-1.fc25
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun May 28 14:40:36 2017
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE) glx: module ABI major version (9) doesn't match the server's version (10)
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the Fedora Project support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: unexpected signal 2
