Fedora Silverblue 42 gcc 15 error loading library libaccdevaux.so CUDA Fortran
Immediately after rebasing from Fedora Silverblue 41 to Fedora Silverblue 42, all my CUDA Fortran kernels failed to launch when running from the host Fedora Silverblue 42 system:
It seems to be related to the upgrade in Fedora from gcc 14 to gcc 15 (which also required a re-installation of the HPC_SDK in order to enable nvfortran to again work).
In order to be able to run my existing CUDA Fortran kernels, I had to launch from a Fedora 41 or lower distrobox (which has gcc 14.2.1). Hopefully the HPC_SDK will be updated in due course to run with gcc 15’s stricter security policies. (the screenshot mentions pygame but the same error occurs with all my CUDA Fortran kernels).
Hi and thanks for the heads up. Since Fedora 42 just came out, our team will be doing testing in the near future.
