How do you disable caching of data in L1 and L2 as much as possible ? (Fermi Architecture)
I saw that in the previous posts, you can disable cache L1, and disable caching in L2 as much as possible by doing the following.
-Xptxas -dlcm=cs
cs means cache streaming, cv means cache volatile.
Isn’t volatile supposed to degrade performance even more ?
Is the SM will try to fetch from memory every time ? or is it that SM happens to fetch from cache (memory…) and cache hit ?
since cv produces better performance than cs… unexpectedly…
Can anyone suggest how I can disable the use of L2 and L1 as much as possible ?
Thanks !
