Once you have that, you can compile the kernel for multiple architectures using the -gencode option to nvcc, so that code best matching the actual GPU is selected at runtime.
I would recommend testing if CUDART_VERSION >= 3000. That will allow your code to compile on older versions of CUDA, and it won’t hurt to call the cache config function on a GPU that doesn’t support it. The call will just be ignored.
You could certainly query the device type from host code using [font=“Courier New”]cuDeviceComputeCapability()[/font].
However, from a maintainability standpoint, if your kernel code has different capabilities on different CUDA devices, I’d rather suggest to announce those capabilities from the device code to the host code. E.g., create a variable in the device with flags for different functions available, and read that from the host code. That way you will never run into trouble by accidentally querying the wrong device in a multi-GPU setup, the driver selecting a code-blob other than the one you expect, or changing device code without updating host code.
If I compile it on the system with GTX480 than is the compilation succesful. If I compile it on the system with GTX285 than I have a compilation error:
error: identifier "cudaFuncSetCacheConfig" is undefined
How I can commpile this code for GTX480 and GTX285?
I use CUDA Build Rule v3.0.14 and compile for sm_10 and sm_20…
Read my post again… You apparently do not have CUDA 3.0 installed on the GTX 285 system and need the ifdef CUDART_VERSION >= 3000 for your code to work compile with older versions of CUDA.
Both systems have CUDA 3.0, but the GTX285 system from 01.2010 and GTX480 system from 03.2010. It’s crasy, both Toolkits have the same version number 3.0, but different versions of the files.
I install the new version auf CUDA 3.0 on the GTX285 system and it compiles succesful on both systems. The compiler ignor the “cudaFuncSetCacheConfig(…)” on the GTX285 system and it works fine.
