Fetching RTX Lidar pointcloud 2023.1.1
Hey looking at the changes mentioned in a previous post for 2023.1.1
I see that…
> import omni.kit.commands
> from pxr import Gf
> import omni.replicator.core as rep
> lidar_config = "Example_Rotary"
> # Create The Camera
> _, sensor = omni.kit.commands.execute(
>     "IsaacSensorCreateRtxLidar",
>     path="/sensor",
>     parent=None,
>     config=lidar_config,
>     translation=(0, 0, 1.0),
>     orientation=Gf.Quatd(1,0,0,0),
> # Create and Attach a render product to the camera
> render_product = rep.create.render_product(sensor.GetPath(), [1, 1])
> # Create Annotator to read the data from with annotator.get_data()
> annotator = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacCreateRTXLidarScanBuffer")
> annotator.attach(render_product)
> # This is the new part, it actually gets the data from the annotator and prints the point cloud data.
> # When the data changes, you have to fetch it again, i.e. every frame if you want it.
> data = annotator.get_data()
> print(data["data"])
In another action graph I can fetch the dataPtr via
import omni.graph.core as og
point_cloud = og.Controller().node("/Render/PostProcess/SDGPipeline/RenderProduct_Isaac_RtxSensorCpuIsaacCreateRTXLidarScanBuffer").get_attribute("outputs:dataPtr").get()
print(point_cloud)
How can I fetch the point cloud array in another action graph? I’m using on tick to fire that graph so it gets the data every tick I will change it to be frame at a later date, I’m just testing atm
Cheers
Got this running via action graph by using two action graphs and a global, i’ll change that later…
from pxr import Gf
from omni.isaac.core.utils.render_product import create_hydra_texture
lidar_config = "ZVISION_ML30S"
global annotator
# 1. Create The Camera
    path="/sensor",
    parent=None,
# 2. Create and Attach a render product to the camera
hydra_texture = rep.create.render_product(sensor.GetPath(), [1, 1], name="Isaac")
# Create the debug draw pipeline in the post process graph
writer = rep.writers.get("RtxLidar" + "DebugDrawPointCloud" + "Buffer")
writer.attach([hydra_texture])
# 4. Create Annotator to read the data from with annotator.get_data()
annotator = rep.AnnotatorRegistry.get_annotator("RtxSensorCpuIsaacComputeRTXLidarPointCloud")
annotator.attach([hydra_texture])```
Then used a on on frame tick to fire the second script node
```data = annotator.get_data()
print(data["data"])```
I'll look at either changing the global command with a path or change the global to something more personalised its really about just getting the data flowing for SDG at the moment!
Hopefully this helps someone!
