Ffmpeg 2 output 50 fps help
Hello
i need help with command i can make 2 output at same time 1080p50fps + 720p50fps with copy all map subtitle and encoding all map audio to aac output hls with using nginx
Thank you
any one can help ?
I don’t think this is really the right place to ask.
You should of course use a search engine and try to find some answers for yourself.
There are pretty much examples for everything out there.
And of course there is: man ffmpeg, or ffmpeg -h.
EncodingForStreamingSites – FFmpeg might give you some hints.
A quick search for “ffmpeg hls” brought up this:
Using FFmpeg as a HLS streaming server (Part 1) – HLS Basics | Martin Riedl
Maybe that’ll help too…
And if you really can’t find a solution after searching and trying, I’d recommend using the ffmpeg mailing list, or maybe their IRC channel.
https://ffmpeg.org/contact.html
But some hints I think I can give: use i.e. -vf "scale=w=1280:h=-1" for scaling. And I think -r is for frame rate.
