FFmpeg nvenc: with Driver does not support the required nvenc API version.
I’ve been trying to run the examples in the NVIDIA FFmpeg Transcoding Guide.
I’m running Ubuntu 18.04 on a Dell G7 laptop with a GEFORCE 1060 card.
What I’ve tried:
ffmpeg -vsync 0 -hwaccel cuvid -c:v h264_cuvid -i input.MOV -c:a copy -c:v h264_nvenc -b:v 5M output.mkv
Resut:
ffmpeg version N-96090-gfb705e4073 Copyright (c) 2000-2019 the FFmpeg developers
  built with gcc 6.5.0 (Ubuntu 6.5.0-2ubuntu1~18.04) 20181026
  configuration: --pkg-config-flags=--static --extra-libs='-lpthread -lm' --enable-gpl --enable-libvidstab --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-cuda-nvcc --enable-cuvid --enable-nvenc --enable-libnpp --extra-cflags=-I/usr/local/cuda/include --extra-ldflags=-L/usr/local/cuda/lib64 --enable-nonfree
  libavutil      56. 36.101 / 56. 36.101
  libavcodec     58. 65.100 / 58. 65.100
  libavformat    58. 35.101 / 58. 35.101
  libavdevice    58.  9.101 / 58.  9.101
  libavfilter     7. 69.101 /  7. 69.101
  libswscale      5.  6.100 /  5.  6.100
  libswresample   3.  6.100 /  3.  6.100
  libpostproc    55.  6.100 / 55.  6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.MOV':
  Metadata:
    major_brand     : qt
    minor_version   : 537331968
    compatible_brands: qt  niko
    creation_time   : 2019-12-10T16:32:33.000000Z
  Duration: 00:01:10.07, start: 0.000000, bitrate: 29869 kb/s
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 28318 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 119.88 tbc (default)
    Metadata:
      encoder         : AVC Coding
    Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s16, 1536 kb/s (default)
    Metadata:
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (h264_cuvid) -> h264 (h264_nvenc))
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
[h264_nvenc @ 0x55b875d5a500] Driver does not support the required nvenc API version. Required: 9.1 Found: 9.0
[h264_nvenc @ 0x55b875d5a500] The minimum required Nvidia driver for nvenc is 435.21 or newer
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Conversion failed!
Output of nvidia-smi:
| NVIDIA-SMI 430.64       Driver Version: 430.64       CUDA Version: 10.1     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 106...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   58C    P0    24W /  N/A |    184MiB /  6078MiB |      2%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0      1615      G   /usr/lib/xorg/Xorg                            97MiB |
|    0      2159      G   /usr/bin/gnome-shell                          84MiB |
I installed the NVIDIA drivers through
sudo apt install nvidia-prime
EDIT: Updated to the latest version of NVIDIA drivers available through the apt system.
As it says in the error message,
, whereas I have 430.64 installed.
I found this thread, in which the issue was resolved by downgrading FFMPEG.
Which version of FFMPEG should I downgrade to, so as to resolve this issue? Or is there a better way?
How do I upgrade nvenc version to 9.1? Thanks in advance.
