Hi Omniverse Team,
Seems like there is a problem with FFT Bloom on Create 2022.3.0, settings except for scale does not affect the FFT bloom effects like it used to in Create 2022.2.2.
Hi Omniverse Team,
Hello @DavidDPD! Thank you for reporting this. I will have the Create team look into this issue!
Hello @DavidDPD
Thanks for reporting the issue.
The display of Physical and Non-Physical settings relative to what model is active is inverted, so when one is selected it is the other that is applied. We’ll fix it for the next release, until then you have to inconveniently change the settings while the results are not visible, then flip the model to the other to see the results.
