When running Fieldiag with multiple cards it only outputs 1 log. It should be creating a .tgz with all the logs from each card. I have checked in the FD folder as well only one log.
This is the output:
Running fieldiag…
Initializing… |====================| 100.0 %
Running test 374 on GPU 0 - 0 tests remaining |====================| 100.0 %
Running test 374 on GPU 1 - 0 tests remaining |====================| 100.0 %
Running test 374 on GPU 2 - 0 tests remaining |====================| 100.0 %
Running test 374 on GPU 3 - 0 tests remaining |====================| 100.0 %
Error Code = 000000000000 (ok)
MODS end : Mon Nov 12 22:04:22 2018 [22101.742 seconds (06:08:21.742 h:m:s)]
Done
[root@localhost Test]# ls
driver.tgz fieldiag_CONFIG_.log NV_Field_Diag_Software.pdf
fd fieldiag_PASS_123456.log NVIDIA-Linux-x86_64-410.72.run
fieldiag install_module.sh
